Sub Panel And Breaker Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-27-2012, 11:25 AM   #16
Master Electrician
What's the diameter of the cable?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 09-27-2012, 11:29 AM   #17
1 1/4" I only did a quick measurement.
Deranged1 is offline   Reply With Quote
Old 09-27-2012, 11:52 AM   #18
Master Electrician
Have you already bought the cable? There's other more cheaper and easier methods.
Old 09-27-2012, 11:53 AM   #19
Cable has been bought, was actually a good price $280 with tax for 36M of it. ACWU90 2 gauge 3 conductor.
Old 09-28-2012, 07:38 AM   #20
Master Electrician
You have to have a radius of bend roughly 6 times the size of the cable. Acwu is good for use in all locations and for exposed wiring but you may want to sleeve it where there might be a possibility of mechanical damage. As long as the termination is in a dry location you can use almost any normal armoured cable connector. If your over 200a it has to be a non ferrous connector but that's not an issue for you.
What I would do is run it up out of the ground in PVC into a deep box and go through the back of the box into the panel. It will look neater this way than having it run up the side of the wall. You can get 10 inch deep PVC boxes. That should give you enough room to make the bend.
As always contact your inspector to double check what they'll want.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 04:27 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
