Sub Panel To Attic Or Not? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 10:01 AM   #1
sub panel to attic or not?
My 112 year old house has three appartments. I'm thinking of re-wiring the two apartments on the second floor from the wide-open attic and dropping the wires down through the walls. I'm considering the cost difference of putting sub panles in the attic vs. running each new circuit up from the basment.
Each appartment is approx. 800 square feet. No washer or dryer, no dishwasher, no garbage disposer, gas range. So not much demand. How many circuits am I likely to need for each appartment and how many 15 amp vs. 20 amp circuits? This will help me calculate the cost differential of running two separate cables and sub panels up to the attic.
I hope I was clear...
Thanks!
ibelieveican is offline   Reply With Quote
Old 04-23-2013, 10:30 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
The breaker panels have to be accessible by they people in the apartments.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-23-2013, 06:36 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Do you have all the required clearances in the attic to install a sub-panel?
Old 04-23-2013, 06:43 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I would have a a sub panel installed in each apartment.
Coastal South Carolina
Old 04-23-2013, 07:25 PM   #5
rrolleston, if the panels must be accessible by the tenants, I would rather just use the panels already in the basement and just run all new wire up from there.
stickboy, yes I do have the required clearance in the attic, but see above.
rjniles, much harder to put the panels in each apartment, and not worth the trouble at this point, but thanks for the input.
Old 04-23-2013, 07:33 PM   #6
E2 Electrician
Thanks!
Minimum you would need...
(2) 20 amp circuits for the kitchen/dining area
(1) 20 amp circuit for the Bath room
(2) 15 amp lighting and general purpose circuits
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
ibelieveican (04-23-2013), OCPik4chu (04-24-2013), Philly Master (04-24-2013)
Attic access panel options SONofAmrfixit Building & Construction 4 03-24-2013 09:30 AM
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 12:50 PM
changing to 200 amp service mbaldwin Electrical 3 03-29-2012 09:00 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 06:27 PM
