Sub Panel Amperage - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2008, 12:23 AM   #1
Sub Panel Amperage
I'm running a sub panel to my shop. It is a double pole 50 amp breaker at the house. Does my sub panel in the shop have to be 50 amps or less or can I install say a 70-100 amp sub panel and just not max it out?
houstonbrama is offline   Reply With Quote
Old 08-17-2008, 07:59 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
The 50 in the house is your overcurrent protection. The larger breaker in the sub-panel is just a disconnect.
You are fine.
Old 08-17-2008, 09:22 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
The sub-panel itself you are installing in your shop would have to be rated for at least the ampereage that it's being protected by....in the scenario you describe, it would have to be rated at least 50 amps. It can be rated for more, but not less. Any breaker used in the sub-panel that is larger in amperage then the feeder overcurrent protection (the 50 A in the house) is going to act as a disconnect. Any breaker less in size will act as an overcurrent device.
Old 08-17-2008, 09:57 AM   #4
Excellent. Thanks for info guys!!
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
