Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 05:01 PM   #1
sub panel
i would like to install a 100amp sub in my new addition...what size romex would i need? and is it ok run romex through floor joists? any info would be appreciated..
jdjan is offline   Reply With Quote
Old 04-07-2010, 05:27 PM   #2
How far a run is it from main to your purposed sub panel? What size main service do you have now?
Paelectrican is offline   Reply With Quote
Old 04-07-2010, 05:39 PM   #3
and....where are you located ?
Old 04-07-2010, 07:00 PM   #4
60 feet and 200 amp main panel..located in New Jersey...
Old 04-07-2010, 07:57 PM   #5
Master Electrician
#3's will work just fine...you'll need red black white and ground in the cable and the sub panel can be a loadcenter with no mains provided it's protected by a 100A breaker at the main service. Double check to make sure that the ground and the neutral AREN'T bonded at the new panel. I honestly don't know if it's legal to drill a hole that size in a floor joist. I would guess it depends on the size of the existing joist but i can't give you an answer on that so i'll let someone else pipe up. I have a feeling you can't though.
I checked it out and in most cases you can drill up to 1/3 the size of the joist as a hole but must be 2.5 inches from the nearest edge so you should indeed be able to run your cable through it.
andrew79 is offline   Reply With Quote
Old 04-08-2010, 12:18 PM   #6
Rewards Points: 82
Look above in the thread titled Stubbies drawings. At the top of the main forum page. There you will find a drawing for your new installation. Use the search function on this forum and use the search term "sub panels" and take advantage of all the years of explaining how to do this. Its all right here for you. You just need to look around. Then if you require more help, please let us know.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
