Sub-panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 03:30 PM   #16
I can use Liquid Tite flexible conduit underground to make some hard turns. With Liquid Tite connectors. Right?
selewis is offline   Reply With Quote
Old 02-21-2010, 05:58 PM   #17
Just call me Andrew
Rewards Points: 1,020
If you use rigid conduit you can try running a string through as you assemble it. Use that string to pull a bigger string (or a rope). THen use the rope to pull your wire. Just a thought.
Andrew
secutanudu is offline   Reply With Quote
Old 02-21-2010, 09:37 PM   #18
why not just thread the conductors as I assemble the conduit?
Old 02-21-2010, 09:50 PM   #19
Inspector/Instructor
codeone's Avatar
How tight of turns are you talking about?
codeone is offline   Reply With Quote
Old 02-21-2010, 09:52 PM   #20
Three 45s and 2 90s (one at each end to come up out of the ground into the conduit body and through the box connector
Old 02-21-2010, 09:58 PM   #21
codeone's Avatar
Are you running pvc pipe? what size? I would personally use pre formed pvc piping underground instead of flex and install a pullstring as I installed it as suggested above. The flex might be hard to pull through at the connectors.
Old 02-21-2010, 10:08 PM   #22
I was going to run 1 1/2" PVC and pre-formed turns except where i had a turn a little less or more than 45 0r 90. But why a string rather than the conductors themselves?
Old 02-21-2010, 10:15 PM   #23
codeone's Avatar
the string would be to pull your conductors in after your piping is finished. I suppose you could install the wire as you go. Most electricians do not put the wire in as you go. Habits I guess.
Reguarding your piping you could heat the piping with a heat gun being careful not to burn it and bend to the degree you need. They also make hot boxes to bend the pipe and heat blankets. Its just that you most likely can come across a heat gun easier, just takes a little patience and practice to make good bends. The pvc becomes quite flexable when heated, you just have to heat a long enough area to make the sweep you need.
Also be careful not to reduce the diameter of the pipe.
Old 02-21-2010, 11:52 PM   #24
Just call me Andrew
The glue (if you are using pvc glue) is a deteriorating agent, it can eat right through insulation if it makes any contact before it dries.
Might not be a bad idea to pull an extra piece of string with your conductors, assuming this is up to code. Then you can use it later to pull another wire if needed. I am not sure if it is safe to have a piece of string in conduit with live wires, though.
Andrew
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
