Old 03-26-2009, 06:13 PM   #1
sub panel
I want to run Electric in my garage. I was told by an electrician that i need 6/4 wire. The onlyplace that i found it was at grainger and it was the most expensive thing i have ever seen in my life. Is that the only wire that i could use and if so is there a cheaper place to buy it?
benv is offline   Reply With Quote
Old 03-26-2009, 06:21 PM   #2
sub panel
you need to decide what size panel you want in there...is it attached or detached?...if you want a 60 amp panel in the back you would use 6-3 with a ground...or you could use aluminum which is cheaper, but you need a bigger size...
NolaTigaBait is offline   Reply With Quote
Old 03-26-2009, 06:33 PM   #3
sub panel
What are you planning to do in this garage?
johnnyboy is offline   Reply With Quote
Old 03-27-2009, 12:33 PM   #4
J. V.'s Avatar
sub panel
The size wire you install for the garage sub panel is determined by the size of the breaker that feeds it, and your electrical demands/needs in the garage. What will you have in the garage? This information is what we need to know before we can advise you on panel size and conductors.
Old 03-28-2009, 09:32 PM   #5
sub panel
what kind of load are their in your garage ? that you can base what circuit protection rating you will use and also with its allowable size of wire you can use.
abbet is offline   Reply With Quote
Old 03-29-2009, 10:17 AM   #6
sub panel
i love this forum...one guy can say something and five guys will say the same exact thing post after post
Old 03-29-2009, 10:45 AM   #7
knowsomethings
sub panel
New Orleans, figures.
Nice reply
runout is offline   Reply With Quote
Old 03-29-2009, 12:01 PM   #8
sub panel
am i wrong here?...three guys followed with the same response...and whats with the "new orleans, figures"....are we known to have a bad attitude around the country?
Old 03-29-2009, 02:52 PM   #9
sub panel
Its a detached garage that one day i would like to have the capability of having as a rental unit but for now i just want to have a shop.
Old 03-29-2009, 02:57 PM   #10
sub panel
Ever notice how one guys says something then a bunch of other guys say the same thing
You need 6/3 with ground, not 6/4
Wait...detached. You should run PVC and individual #6's THWN. 2 blacks, 1 white and a #10 green ground. Also, drive a ground rod or two.
Grainger is not a place you want to buy wire....or anything. Home Depot.
220/221 is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
