Sub Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 01:52 PM   #16
True that. Fortunantly my garage is a little different. I have a Gas heating unit, and another of other things. But if it was just a shed that would be funny and a lot of work.
BenJoeM is offline   Reply With Quote
Old 11-16-2008, 11:51 PM   #17
Rewards Points: 506
Send a message via AIM to theatretch85
Not really a lot of work, the 60 amp disconnect is simply a disconnect at the outbuilding rated for 60 amps. Your feeder could be a 30 amp breaker at the house, but at the other end the disconnect for the structure must be rated for at least 60 amps. This is not to say that the disconnect can't be bigger; IE: if you are running a 100 amp service to another building/garage/shed etc.
theatretch85 is offline   Reply With Quote
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
