Sub-panel For 3 Space Heaters - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 10:08 AM   #16
Rewards Points: 127
Heaters--eager to shop for supplies
Hey Missouri Bound!
The heaters I have are no longer in production. Here is a link to the newer ones...
www.steffes.com/off-peak-heating/room-units.html
The new models have variable-speed fans and more (digital) programmability.
BTW, I do NOT need to run neutrals because devices will always be 240 VAC, RIGHT?
Can I use what would otherwise be the neutral bus bar in the subpanel for all the equipment grounds?
Can I get away with #4 CU THHN feeders if I use a 100A subpanel, knowing that I may have a continuous load up to 80A? (I have some #4, but no #3.)
Thanks a lot,
Daneel
Bonjour Marc,
I am delaying optimum placement of heaters because certain floor areas will not support the weight -- one of the reasons heaters may be moved.
My main concerns are getting breaker ratings, AWG sizes and other code details right. I think I have these correct in [Q6.1] earlier.
Merci beaucoup pour votre soutien.
Daneel
Daneel is offline   Reply With Quote
Tags
ground rod , space heater , sub-panel
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 10:50 AM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Sub Panel SoxFan Electrical 2 12-02-2008 11:16 AM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
