Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2015, 04:03 PM   #1
Rewards Points: 4
Sub panel
I have a question I am installing a sub panel in my garage approximately 60 feet from house I am running 1 double pole 15 amp for my air compressor .1 15 amp. for plugs 8 of them and 1 15 amp for 4 fluorescent lights all wires are 14-2 in the garage in the main panel in my house I have a double pole 30 amp breaker and I am running 10-3 with ground through the plastic conduit is 10- 3 sufficient enough? Note air compressor is 230 volts 14 amps.
kirby78 is offline   Reply With Quote
Old 03-12-2015, 04:10 PM   #2
Electrician/DIY fanatic
Vegas Sparky's Avatar
Rewards Points: 606
Who wired garage receptacles with 14-2? You'll have problems with that circuit tripping if any substantial power tools get used.
The 10ga wire size is fine on a 30A breaker. If you are pulling 10-3 NM cable in conduit, that is not an approved method of installation.
William
My current DIY project..
Vegas Sparky is offline   Reply With Quote
Old 03-12-2015, 04:42 PM   #3
Rewards Points: 484
Given free choice, I would put a 60 amp breaker in the house and feed out #6/3 with ground to the sub panel which COULD be whatever is cheesy at HD, for example their 100 amp boxes are less eensive that trucking around finding a 60 amp. As noted, I would ALSO wore the entire garage except for lighting with minimum 12 wire using 20 amp breakers. Little if any difference in installation effort and a big step up in handling whatever your futureower needs might be. And remember that you have different requirements for an ATTACHED garage vs a DETACHED garage, specifically a grounding electrode in the latter. Ron
ront02769 is offline   Reply With Quote
Old 03-12-2015, 04:52 PM   #4
Rewards Points: 4
Not sure on whi wired it but thanks
Old 03-12-2015, 05:06 PM   #5
Rewards Points: 4
What would the improved insulation be on that wire from house to garage
Old 03-12-2015, 05:34 PM   #6
Oso954's Avatar
Rewards Points: 1,336
Individual conductors of THWN wire. (most THHN is dual rated as THWN)
You could also use UF cable.
Oso954 is online now   Reply With Quote
Old 03-12-2015, 06:26 PM   #7
joed's Avatar
Rewards Points: 13,346
14/2 is fine for a 15 amp circuit. I have never had an issue running power tools on a 15 amp circuit.
Old 03-12-2015, 06:55 PM   #8
Rewards Points: 484
My porter cable double side stack cores or for my nail guns will blow that every single time. Been there, done that. Ron
Old 03-12-2015, 07:01 PM   #9
Rewards Points: 1,402
Concur--15 amps is more than enough for most things, and the wire is cheaper and a little easier to work with for people without much experience. The only time I've run into issues where 15 amp circuits are inadequate is with multiple heavy loads, like multiple space heaters or a powerful vacuum and a big laser printer, etc...
So a 20 amp might be useful in a garage if you have a lot of people over working on a project and running different tools, but a 15 amp is only an inconvenience maybe once in five or ten years.
One exception--if you're in a cold climate and have a heated garage with any pipes, obviously make sure there's extra electric capacity there in case your main heat goes out at any point and you need to use electric as a backup.
Tom738 is offline   Reply With Quote
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 03:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
