Sub Panel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-19-2008, 10:56 AM   #31
Rewards Points: 240
That other wire that The NM connects to is "what". I'm not trying to beat a dead horse to death, but I would want to be sure the feeder is installed properly, with the correct conductors.
J. V. is online now   Reply With Quote
Old 06-22-2008, 12:37 PM   #32
The wire kinda looks like an old cloth heavy shield wire... what was the code in the 60's it passed when the bought the house in the 80's my fear is if the conduit is rusted out i may not be able to pull wire threw it after i get the old wire out but i see no sign of damage to the conduit.. wonder how long it lasts
i have NM 10=3 to the jbox just 1 ft before it enters the ground and NM at the Outside 90 j box... so id say if it is a different wire wire running in the conduit i hope it's correct
Pic 01= In side outside box
Pic 02= Where conduit enters ground
Pic 03= what would have to be dug up for new conduit (not an option)
Evnldr is offline   Reply With Quote
Old 06-24-2008, 11:37 PM   #33
anybody know what kinda wire it is?
Old 06-25-2008, 09:20 AM   #34
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
It looks like the old rubber impregnated cloth we used when I got started in the trade. We used it for everything. Including in conduit to garages. How many conductors in the cloth covered wire? Is there a woven wire sheath under the cloth or just individual wires? Tell us as much as you can about the original feeder wire. Can you find it in the basement?
John
jrclen is offline   Reply With Quote
Old 06-25-2008, 10:23 AM   #35
It dose look like rubber. it's 10-3 glad to see it is in code id hate to try to remove it
Old 06-25-2008, 07:38 PM   #36
jrclen's Avatar
Rewards Points: 514
10-3 with ground? 4 total wires? Have you looked in the basement panel to see if all 4 are connected and that the connections look solid?
John
Old 06-28-2008, 05:22 PM   #37
yea they look solid to me... long as it is to code I'm happy.... not my house but I still care... I'm looking at getting a new house...so I'm sure more to come
Old 06-29-2008, 10:55 AM   #38
Rewards Points: 240
The question needs to be asked. "Is this cable suitable for wet locations" Even in buried conduit it must be rated for wet locations. Since you say rubber, it may very well be suited for wet locations, but I would not know. It sure looks like the old NM type to me, no EGC.
That conduit would be the kicker for me. It would be gone and new conductors pulled in. And you are correct regarding pulling the cable out. You probably will not be able to remove it.
Old 07-08-2008, 07:20 AM   #39
You need to unbond the neutral bus from the chassis and add a separate ground bus, bonded to the chassis! Ground and Neutral should be separated in a subpanel or it will carry stray voltage back to the main! I don't think you said what the distance to the main was.
Here is a handy chart:
http://www.frentzandsons.com/Hardwar...iesofcoppe.htm
Glid is offline   Reply With Quote
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
