Sub Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 06:01 PM   #16
Master Of Nothing
mr500's Avatar
Originally Posted by chris75 View Post
Its probably fine, the well pump most likely has its own thermal protection.
YES it does I bought it that way. as well it has the low pressure cut out.
mr500 is offline   Reply With Quote
Old 03-08-2008, 06:27 PM   #17
Electrician
Your fine, if your picture showed the bottom of the panel this all never would have even been talked about...
chris75 is offline   Reply With Quote
Old 03-08-2008, 06:45 PM   #18
When is fishing season?
CowboyAndy's Avatar
You cant always say that, you could easily have a 30amp breaker on a 14 AWG wire suppling a AC unit...
I must have missed where he said it was going to an AC unit...
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-08-2008, 07:00 PM   #19
Master Of Nothing
mr500's Avatar
OK thanks guys. Ill be putting this all together in a few weekends. Soon as I can mount in my other equipment grounds buses. The sub panel I bought does not have one so I have to mount another on in there. Ya know that neutral and gnd has to be separated in the sub lol
MIke
Old 03-08-2008, 08:08 PM   #20
Electrician
i was just giving an example, but the OP does have an AC unit, talks about it in post #3
Old 03-09-2008, 03:13 AM   #21
" Euro " electrician
frenchelectrican's Avatar
Mr 500.,,
I know you don't belive me but just turn the A/C breaker off then read the label on the romex wire itself or unscrew the breaker and pull the wires you will see how someone did really shroddy work and also follow that set of wire to the A/C if they are termated the same way just look at the breaker itself.
senice you mention your home is only 5 year old and that wire is brand new then i am pretty much sure it is a 14 gauge you will see on the marking on the cable coating.
Merci, Marc
Old 03-09-2008, 07:28 AM   #22
CowboyAndy's Avatar
Originally Posted by frenchelectrican View Post
Mr 500.,,
Merci, Marc
Marc, apperantly it is #8 or #10 in the jacket for #14...
MY HOUSE OWNS ME!
Old 03-09-2008, 09:44 AM   #23
Electrician
Mr 500.,,
Merci, Marc
I need to see another picture of this panel, its either UF in that 30 amp breaker or two sets of NM, but I need to see a picture of the bottom of that panel before I make up my mind...
Old 03-10-2008, 04:04 PM   #24
Master Of Nothing
mr500's Avatar
Mr 500.,,
Merci, Marc
For the last time, lol. There is only 1 (One) wire going into the 30amp breaker. The picture is deceiving I know. I took the cover off the panel and looked at it this morning. ONE wire. Mike
Old 03-10-2008, 04:14 PM   #25
Unstripped, fat UF going to the A/C
220/221 is offline   Reply With Quote
Old 03-10-2008, 04:34 PM   #26
Master Of Nothing
mr500's Avatar
Yes the wire sheathing is VERY fat/thick. But its ONLY ! WIRE>
Mike
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
New meter panel tomreva Electrical 3 01-08-2008 03:56 PM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 05:47 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
