Sub-panel 12/24 Circuit SQ D Vs. Cutler Hammer - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2013, 05:15 PM   #1
Sub-panel 12/24 circuit SQ D vs. Cutler Hammer
Hi New to forum - got a bid from an electrician to replace my outdated sub panel. I was told when negotiating contract they would be using a Square D panel. Today when I went to see how my install was going they had put in a Eaton BR Cuttler Hammer panel.
When I questioned them they gave me a story about size of box.
Other than be annoyed about the bait & switch...Should I be concerned about the Cuttler Hammer panel? The reviews online are not nearly as good as the Sq. D panel.
sunshinegirl is offline   Reply With Quote
Old 11-21-2013, 05:56 PM   #2
Oso954's Avatar
Rewards Points: 1,630
I would not worry about substituting a cutler hammer panel for a square D homeline.
If the job was bid for a Square D QO, you should either get what you paid for or some money back.
Were you paying attention to the difference between the Square D Homeline and the QO when reading those online reviews ?
Oso954 is online now   Reply With Quote
Old 11-21-2013, 05:57 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If you paid for Sq. D I would expect to get Sq. D, as far as width is concerned, they are usually 14.5", heights can vary depending….
With that said, its a panel, they are all UL listed and operate under the same testing… so they are all equal in that aspect.
The Following User Says Thank You to stickboy1375 For This Useful Post:
sunshinegirl (11-22-2013)
Old 11-21-2013, 06:06 PM   #4
Licensed electrician
Rewards Points: 1,874
Square D Home line and Cutler Hammer BR are comparable panels. Square D QO is similar to the CH brown panels.
Old 11-21-2013, 07:43 PM   #5
Rewards Points: 582
poor business practice to do that without your consent... I would want what was quoted...imo ben sr
Old 11-21-2013, 11:15 PM   #6
Rewards Points: 1,192
I would side with Ben.Cost difference? What else did they shave off the job?
bobelectric is offline   Reply With Quote
Old 11-22-2013, 12:10 AM   #7
220,221,whatever it takes
Rewards Points: 33
This.
Bernie Brewer is offline   Reply With Quote
Old 11-22-2013, 01:03 AM   #8
Thanks all! I am going to leave the CH panel in. I did let them know I did not appreciate them switching to another panel. I have not paid for all work yet. We'll see if he wants to create goodwill maybe we will knock some off his bill.
Old 11-22-2013, 07:49 AM   #9
at my local menards, the br panel is $10.50 cheaper than the homeline but the homeline panel is a 'value pack' panel that comes with two 20 amp, single-pole breakers. subtract the value of those and the contractor is only saving $3 or so by using the cutler hammer.
to each their own but i personally wouldn't worry about it or bring it up again.
itsnotrequired is offline   Reply With Quote
Tags
electrical box , sub-panel
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Extending Wiring Before Circuit Panel... Zeigh Electrical 3 03-02-2013 07:36 PM
Need help finding interlock for Cutler Hammer panel mikegp Electrical 5 02-07-2013 07:25 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
