Stupidest Question Yet!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 11:33 AM   #1
When installing a cut-in box, does it matter which way you punch the knockouts to fish the wire through?
Sorry for such a stupid question!
mopowers is offline   Reply With Quote
Old 03-14-2010, 11:38 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Yes, they need to be punched towards the inside of the box because they are actually acting as a clamp.
No such thing as a stupid question.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
mopowers (03-14-2010)
Old 03-14-2010, 01:20 PM   #3
Thanks. I figured there was a right and wrong way. I'm glad I asked.
Old 03-15-2010, 09:54 PM   #4
Is it okay to feed two 14-2 wires through one knockout?
Old 03-15-2010, 09:59 PM   #5
Rewards Points: 894
I don't think it would be too easy to punch them in the wrong direction. They are hinged in such a way to be punched from the outside.
As for the two #14 cables, I don't know what code says about that. I don't like it though. It might compromise the action of the clamp, allowing both cables to slip out.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 03-15-2010, 10:03 PM   #6
Licensed electrician
Rewards Points: 1,616
One wire per clamp on the style of box shown.
Old 03-15-2010, 10:14 PM   #7
Thanks guys! It's going to be a pain in the butt trying to feed one wire from one of the bottom knockouts with the top four filled. Oh well, maybe I'll invent some new cuss words.
Old 03-16-2010, 06:15 AM   #8
Just call me Andrew
Rewards Points: 1,020
If you have that many wires, there's a chance you are overfilling the box. There are limits based on cubic inches. Take a look at this thread:
Can I use this switch??
Hehe, turns out that thread is yours too. Guess you already knew!
Andrew
secutanudu is offline   Reply With Quote
Old 03-16-2010, 08:14 AM   #9
Counting 5 2 conductor cables and 2 devices plus the ground gives a conductor count of 13. 13 #12s = 29.25 ci. That box should have more than enough space.
Old 03-16-2010, 08:57 AM   #10
Just call me Andrew
I didn't know if that box in the picture was the one he was using.
Andrew
Old 03-16-2010, 09:15 AM   #11
Thanks for the input guys. The box will have (5) 14/2, 2 devices, and a ground. I calculated the min size at 30. The box is 34ci so I should be good to go.
Old 03-16-2010, 01:58 PM   #12
Household Handyman
Rewards Points: 1,408
On "snap-in" boxes, as pictured, I've found it easier sometimes to pull all wiring in before installing the box in the wall--IF you've left yourself enough wire. David
Old 03-16-2010, 07:38 PM   #13
Well, crap. I acidentally snapped one of the knockout clamps off when I tried to push a 14-2 through with another 14-2 already pushed through the knockout directly below it. It's a really tight turn!! Is this box junk, or can I just not use the knockout with the broken clamp??
Old 03-17-2010, 08:53 AM   #14
Rewards Points: 894
I think you could use electrical tape to cover over the open knockout that you aren't going to use. I cannot say for sure that it is code, but it is what I would do.
FW
Old 03-17-2010, 10:43 AM   #15
FW
Something tells me that wouldn't compliant w/ NEC.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
