Is This A Stupid Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 12:48 PM   #1
Rewards Points: 2,166
is this a stupid question
The vent in a bathroom doesn't work. The Home inspector said he didn't know if it 'didn't work, or wasn't installed'.
Is there anyway to check if one is there? Maybe not if the inspector couldn't tell.
Maybe I'll just add that to my list of things for when I get an electrician.
Startingover is offline   Reply With Quote
Old 04-27-2012, 12:53 PM   #2
did you mean the HVAC vent?
BNTHERE is offline   Reply With Quote
Old 04-27-2012, 12:53 PM   #3
Rewards Points: 13,712
Are you 100% sure someone hit the right switch to turn it on?
It can be tested to see if it's getting power, remove the cover and look for where the fan plugs in and test with a meter.
Old 04-28-2012, 01:05 PM   #4
sorry I wasn't clear. This is the Exhaust Vent in a bathroom. I see the vent in the wall, and all the switches work but that one.
Are you saying take the switch plate cover off or the vent cover off?
thanks
Old 04-28-2012, 02:17 PM   #5
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Take the cover of the wall vent and check to see if fan is plugged in. This may have been unplugged because of noise the fan has caused.
HIVOLT is offline   Reply With Quote
Old 04-28-2012, 04:23 PM   #6
Thank. That would simplify one problem on my checklist if this is all that's wrong.
Old 04-28-2012, 06:29 PM   #7
Ravenworks's Avatar
There are no stupid questions,that is how one learns.
Ravenworks is offline   Reply With Quote
Old 04-29-2012, 12:25 AM   #8
dmxtothemax's Avatar
Rewards Points: 5,354
Another thing to check !
These types of fans usually suffer from the oil gumming up over time,
Sometimes they just need the bearings cleaned and oiled up,
And away they go again.
dmxtothemax is online now   Reply With Quote
Old 04-29-2012, 07:50 AM   #9
cleaning bearings???
I'd guess I'd remove the fan, then use a solvent and brush. If I can spot where the bearings are.
We used to have a gas station and we used gas to clean everything.
Old 04-29-2012, 08:22 AM   #10
I=E/R
a7ecorsair's Avatar
Gasoline is quite flammable so something like WD-40 is much safer.
a7ecorsair is offline   Reply With Quote
Old 04-29-2012, 08:39 AM   #11
Rewards Points: 1,192
Sometimes you need that noisey fan.
bobelectric is offline   Reply With Quote
Old 04-29-2012, 12:46 PM   #12
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
If the fan is noisey there may be a retrofit kit available for it. Lowes is carrying an upgrade kit for the Nutone 696N fans. They will fit some of the Broan units as well. The 696N fans were the units we use in the builders grade (cheap) installs. I know I have been installing them all the way back to the early 70's. The upgrade kits are quieter and move more air.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 04-29-2012, 02:09 PM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 1,820
Bearings? Yea...right....more like a brass sleeve.....
In most cases, not worth fixing if it is the fan and WD40 doesn't work. In almost all cases where I used WD40 to get something going....the bearings (brass sleeve) was shot so the fan needed replaceing anyway.
Old 04-29-2012, 08:17 PM   #14
They generally are brass sleeves !
But I use the term bearings because even lay man understand it.
Any way usually a clean and oil will get them going again.
Easy stuff.
LP / NG - Unusual Question... Peter B. Appliances 8 04-09-2011 08:59 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
maybe stupid question: marker for concrete amakarevic Building & Construction 2 06-30-2008 04:17 PM
