Stupid Code Book - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 10-28-2009, 09:52 PM   #1
2green
stupid code book
where in the code does it say that a junction box has to be grounded
2green is offline
Old 10-28-2009, 10:03 PM   #2
Residential Contractor
Only in about a zillion places, provided that the box is metal.
rselectric1 is offline
Old 10-28-2009, 10:08 PM   #3
2green
reply
thanks have a harder question you interested
2green is offline
Old 10-28-2009, 10:11 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Just about everywhere in the codebook if you have metal box yes you must ground it properly.
{ it the same way in France so it is no diffrence at all }
Merci.
Marc
frenchelectrican is offline
Old 10-28-2009, 10:18 PM   #5
2green
heres one; four conductor 10awg mc connected to a 3 pole breaker in a 120/208 volt 3 phase 4 wire panel board and is used for a multiwire branch circuit to serve several 120 volt computers nonlinear loads when calculaing the ampacity of wire is the neutral counted as a current carring conductor?
2green is offline
Old 10-28-2009, 10:24 PM   #6
This setup is very common and what more you will have to understand the Haromaic effect and the result some area you will have to use super netural aka larger netural than phase conductors
However with that question it is moot point due you did not tell us what is the load so I can able tell you the answer.
Merci.
Marc
Old 10-28-2009, 10:28 PM   #7
Yes. 2008 NEC 310.15(B)(4)(c)
...as Marc said, it is due to harmonics.
Willis
williswires is offline
Old 10-28-2009, 10:32 PM   #8
2green
Oh contrair monfrair its on my home work im an apprentice you should be able to get an answer if journeyman are familar with the code. im having problems with this code book thats why im here.
2green is offline
Old 10-28-2009, 10:33 PM   #9
2green
thanks willis you are the man!
2green is offline
Old 10-28-2009, 10:46 PM   #10
2green
here is another brain teaser a transformer is supplied by a 277v circuit. The transformer delivers 24volts for use in a control circuit. are one of the two 24volt wires requierd to be grounded by the NEC?
2green is offline
Old 10-28-2009, 11:11 PM   #11
Yes and No depending on if on class two supply or class three supply that will make the diffrence and IIRC it will be in art 250 { not sure which spot due they change some of details }
The same way with French Electrical codes
Oh by the way I am not Journeyman I am in Master electrician in both Wisconsin and Paris France so I am famauir with both of them.
Merci,
Marc
Old 10-28-2009, 11:18 PM   #12
2green
thanks online people
thank guys im tring to cram for midterm i finished my homework just wanted to let yall know you have been a big help even you frenchy. now my new born needs me good night online people thank again
2green is offline
Old 10-28-2009, 11:22 PM   #13
2green
sorry had to go let you know tomarrow thanks again french electrican
2green is offline
Old 10-29-2009, 05:17 AM   #14
the Musigician
DangerMouse's Avatar
man, it's just not fair.
when i went to school, there was a library where you went TO it to get information.
nowadays, you just go online and have other people do your homework for you....
it's just not fair....
DM
DangerMouse is offline
Old 10-29-2009, 10:08 AM   #15
It is best to understand "why" as opposed to just going by the "rules"...
As for the grounding of the electrical box, basically ANYTHING metal around electrical wiring should be grounded. Another term is bonded.
The reason for this is that a wire can come loose and touch that metal. Then a person comes along, touches the metal, then may be electrocuted.
If the metal is grounded and a "hot" wire touches the metal, this will create a short, overload the breaker, the breaker will trip turning off the electricity, and the metal is then safe to touch by a person.
So you will see all metal associated with electrical things grounded. Ranges, washers, dryers, electrical boxes, circuit breaker panel/cover, etc.
Billy_Bob is offline
Closed Thread
Residential-only code book or book recommendation? tigereye Electrical 7 03-03-2009 12:45 PM
online code book ponch37300 Electrical 3 01-26-2009 08:06 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
I need a code book - 680.43 jamiedolan Electrical 14 11-08-2008 01:21 PM
national building code book smallcrpt General DIY Discussions 2 11-13-2007 07:09 AM
