Stumped By Bathroom Electrical Issue. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-24-2012, 08:41 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
If the lights work from the switch after your test. the wiring going to the lights is good.
Do you have a meter?
Old 11-24-2012, 08:51 PM   #17
Rewards Points: 1,426
The wiring going from the switch to the cans is fine. The wire going into the switch box for the lights is dead. I don't get it. I have a voltage tester with the two "pens" with prongs.
mikegp is offline   Reply With Quote
Old 11-24-2012, 10:05 PM   #18
Originally Posted by oh'mike View Post
I would start right at the breaker box---begin the search at the beginning of the run----bathrooms often have more than one circuit---
Look for a gfci breaker---it will have a handle and a push button---
If that yields no results---flip all breakers on and off just in case you have a partially thrown breaker--
If that fails--I'd open the cover and test each breaker---
If that fails----look for a tripped gcfi somewhere in the house or outside----houses built in the 1970s often used one gfci outlet to protect the whole danged house---
When was your house built? You do have a tester with two wires?
House was finished at the end of 08. All of the lights are on the same breaker, yet some are still working. Nothing else is tripped anywhere in the house that I can find. Unless there's a hidden gfi somewhere. I do have a voltage tester.
Electrical split in bathroom? wjmtemple Electrical 4 11-22-2011 06:13 PM
Old Bathroom - all electrical on one circuit? how to change? Steve19 Electrical 16 03-14-2011 10:32 AM
Bathroom rug issue dinosaur1 Interior Decorating 11 02-19-2011 11:13 AM
Need some help with garage electrical issue Holt Electrical 25 06-21-2010 01:59 PM
Bathroom ventilation / window privacy issue Michael Thomas General DIY Discussions 10 05-26-2009 10:09 AM
