Stud Right Where Light Box Needs To Go.. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 06:57 PM   #31
rjniles and oso954, those are interesting boxes... I wonder if those are code up here in Ontario, as I was planning on getting it inspected even though I was doing it myself. Thats actually a neat idea.
I have a 14g circuit for the lights and bath fan, and a 14g for the recepticals. SOooo I could change my wiring plan to make use of the pancake.
THanks for everyone's input, this site is great!
CharlieR is offline   Reply With Quote
Old 10-29-2012, 08:30 AM   #32
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
How close to the edge of the stud is center?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-29-2012, 09:15 AM   #33
Unfortunately, it's almost dead center on the stud. I can shift left or right a bit based on moving the vanity a bit in either direction.
Old 10-29-2012, 09:51 AM   #34
Rewards Points: 6,652
If you can move the vanity that is fine. Easier to do that, than move a stud. Persoanlly the pancake box is going to be te quickest and easiset solution.
Old 10-29-2012, 10:07 AM   #35
electures's Avatar
Nail a new stud along side of the existing stud then notch the existing stud and install box on the new stud right where the notch is.
Old 10-29-2012, 12:00 PM   #36
Rewards Points: 77
If the space isnt finished, this would clearly be the answer. I think the space is finished already though.
patented is offline   Reply With Quote
Old 10-29-2012, 12:26 PM   #37
they make a ceiling box that will stradle a stud
Mule98 is offline   Reply With Quote
Old 10-29-2012, 01:36 PM   #38
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
AKA,A pancake box.
sublime2 is offline   Reply With Quote
Old 10-29-2012, 02:44 PM   #39
electures's Avatar
Good point. ANy of the options offered by some of the other profressionals is clearly better then having it off center by two inches. In a 20" space, 2" would stand out like a sore thumb and scream "an amature did this".
Old 10-29-2012, 02:57 PM   #40
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
There is no question. Install the stud straddling box and have it centered.
John
jrclen is offline   Reply With Quote
Old 10-29-2012, 03:25 PM   #41
Licensed electrician
Rewards Points: 1,598
Two styles are shown in post #23 and 26.
Old 10-29-2012, 04:33 PM   #42
electures's Avatar
Then use the box pictures in post#26 and be done with it.
Old 11-01-2012, 11:13 AM   #43
Bombastic Idiot
notmrjohn's Avatar
Don't assume a wall is load bearing or not by its direction or what is directly under a portion of it. It may support or be supported by joists or beams running perpendicular to it, soemtimes at some distance from where you are working, the entire wall is integrated, relying on each part to transfer load.
If twere me, and wall is open I would put in new studs a few inches to each side, so they're out of the way, no sistering,they're like 3 bucks a piece, and notch and leave in place the old one, you may need it there for wall board joint or hanging vanity and extra studs can help there too. But are any of these studs going to interfere with plumbing?
Even if you're a quarter inch off center, and you're the one who put it there, you're gonna see it every time you're within eye sight of it.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 11-01-2012, 11:27 AM   #44
Rewards Points: 756
The saddle box is what you want.
Mark
busman is offline   Reply With Quote
The Following User Says Thank You to busman For This Useful Post:
jrclen (11-01-2012)
Old 11-06-2012, 12:00 PM   #45
Thanks notmrJohn and everyone else.
In terms of load bearing, there is definitely no perpendicular support underneath, other than the exterior wall at one end. I guess that still doesn't necessarily mean anything.
I will sister or add support if I do notch for sure. There is a chance it will interfere with plumbing, as I have vanity plumbing running through that wall. The biggest problem would be the drain, but I can deal with that if must be as I haven't finished that section anyhow. The supply plumbing I'm having another issue with and again, can address that if need be.
I'll see if I can find one of those saddle boxes, haven't seen them in Ontario before.
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
