Stud Right Where Light Box Needs To Go.. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 02:38 PM   #16
Rewards Points: 6,652
Originally Posted by CharlieR View Post
thanks mpoulton
gregzoll... are you saying appearance wise? Or functionality wise, aka, the plate will cover it?
Both. Use a Old work or a "Smart" box. No one will notice that it is a little to the left or right.
Old 10-27-2012, 02:39 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
In your opinion, maybe... but that would never fly with me... I would see it in a heart beat.
The Following User Says Thank You to stickboy1375 For This Useful Post:
electures (10-29-2012)
Old 10-27-2012, 02:56 PM   #18
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Hello,
I'm trying to center a lamp right over the middle of a sink,
Charlie
2" in either direction of center WILL be obvious to the eye.
Notch the stud. Put some side support studs in if your concerned about load.
sublime2 is offline   Reply With Quote
Old 10-27-2012, 03:03 PM   #19
Sbulime, no 2" will not be noticeable when it comes down to it. As for the pancake boxes, they make them so that you do not have to notch out the stud, you just have to cut the drywall to be able to secure the straps to both sides of the stud.
Old 10-27-2012, 03:03 PM   #20
E2 Electrician
Good luck with that... lol...
Old 10-27-2012, 03:14 PM   #21
Bombastic Idiot
notmrjohn's Avatar
Electricians are always notching studs that I put in. Some, note, gentlemen, I said "some", have no idea if it is load bearing or not, or how much they can cut out. At least they're not as crazy as some plumbers, who will cut out an entire section of stud to run a 3" line.
If you are absolutely sure this is non load bearing, ( and I should ask how you know it is not load bearing before I continue) there should be no problem in notching it. As long as you do not notch deeper than 40% of stud. In a 2x4 that's 1 7/16". And notch should be as low as possible.
Occasionally a stud will warp or bend if notched because of they way wood fibers of grain run and inter-mesh. If the wall is open on this side, you said you could sister the stud so I assume it is, it would be best to put in a new or couple of new studs on each side of notched one, rather than notched sisters.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
The Following User Says Thank You to notmrjohn For This Useful Post:
stickboy1375 (10-27-2012)
Old 10-27-2012, 03:20 PM   #22
Thanks notmrjohn,
I guess I don't know 100% that it is not load bearing. It runs perpendicular to an outside (obviously load bearing) and an interior non load bearing hallway wall. I assume the hallway is not load bearing becuase the otherside of the hallway appears to be, becuase it runs down through the house all the way to the basement on what I believe are load bearing walls. Now, there are several of these perpendicular walls, in each of the rooms along the hallway. Only two of them have walls on the main floor beneath. Is it safe to assume then that bathroom wall is not load bearing since there isn't anything underneath it?
Im ok with adding studs on either side as well. Other than having to run piping through them!
CharlieR is offline   Reply With Quote
Old 10-27-2012, 03:39 PM   #23
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
I have used this fan rated box for wall mounted fixtures:
It has 13.5 cu in and will allow the use of (2) 12-2 cables. It installs just like a pancake with no cutting of the stud required.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
electures (10-29-2012), Jim Port (10-29-2012)
Old 10-27-2012, 03:39 PM   #24
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Maybe not in your bathroom .......
What if the wall he's dealing with is say, 20" in width?
You will see it.
Old 10-27-2012, 03:41 PM   #25
In my bath, our fixture is offset, and when you look at it, you cannot tell, unless you really look hard.
Old 10-27-2012, 04:57 PM   #26
Oso954's Avatar
Rewards Points: 1,664
I haven't run into RJ's box before.
But a similar idea is a fan rated saddle box.
Oso954 is online now   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
Jim Port (10-29-2012), jrclen (10-27-2012)
Old 10-27-2012, 05:09 PM   #27
Rewards Points: 14,312
http://www.bing.com/images/search?q=...5AB5C4&first=1
Far simpler then notching.
Old 10-27-2012, 05:50 PM   #28
Rochsolid's Avatar
Hello,
I was wondering, not sure if it's a local code thing or not, if a non-load bearing stud can be notched for a light box on a wall? I'm trying to center a lamp right over the middle of a sink, and unfortunately, there is a stud right there. SO I was wondering if it's ok to notch it enough to put the box basically in the stud? I know there are those pancake boxes, but would rather not do that. I can/will sister the stud just in case...
Other options are offsetting the box and getting a light fixture with a large enough wall plate to cover it, but Id rather not unless notching the stud really isn't to code or a good idea.
THoughts/opinions/advice? Thanks in advance....
Charlie
Depends on what type of light you ate installing. I you are using a light where there is a mounting plate (the length of your fixture) you can mark your centre mark on your mounting plate and drill a hole through the plate and put a plastic bushing in it and mount your fixture with toggle bolts
Rochsolid is offline   Reply With Quote
Old 10-27-2012, 06:03 PM   #29
A "Handy Husband"
rjniles's Avatar
The problem with a pancake is they are only 6 cu in, enough for a single 14-2. If you have a single 20 amp circuit for the bath (lights and recept), you can not connect a single 12-2 to a pancake (and meet code).
Old 10-27-2012, 06:06 PM   #30
A "Handy Husband"
rjniles's Avatar
Originally Posted by joecaption View Post
Joe,
That pancake with an internal clamp will not even allow a single 14-2 and meet box fill.
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
