Stud Right Where Light Box Needs To Go.. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 01:21 PM   #1
Stud right where light box needs to go..
Hello,
I was wondering, not sure if it's a local code thing or not, if a non-load bearing stud can be notched for a light box on a wall? I'm trying to center a lamp right over the middle of a sink, and unfortunately, there is a stud right there. SO I was wondering if it's ok to notch it enough to put the box basically in the stud? I know there are those pancake boxes, but would rather not do that. I can/will sister the stud just in case...
Other options are offsetting the box and getting a light fixture with a large enough wall plate to cover it, but Id rather not unless notching the stud really isn't to code or a good idea.
THoughts/opinions/advice? Thanks in advance....
Charlie
CharlieR is offline   Reply With Quote
Old 10-27-2012, 01:47 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by CharlieR View Post
Hello,
Charlie
Whats wrong with a pancake box?
Old 10-27-2012, 01:50 PM   #3
Nothing I suppose... I think you're only suppose to have the fixture and one set of 14g wires coming in right? My original plan was to have the power enter this fixture, and then go to the next and then to the switch, so I"d have to rearrange that... plus feeding the fixture first, so that would be 3 14g, plus the fixture wires....is that not too much even if I did change my plan?
Old 10-27-2012, 01:51 PM   #4
E2 Electrician
I would keep it to one 14-2 , just change the wiring plan.
Old 10-27-2012, 01:53 PM   #5
So with a pancake box, I don't notch the stud at all? It's meant to just go the drywall depth right?
Old 10-27-2012, 01:54 PM   #6
Master Electrician
Rewards Points: 3,874
Move the stud.
brric is offline   Reply With Quote
Old 10-27-2012, 01:54 PM   #7
E2 Electrician
Yes. Thats correct.
Old 10-27-2012, 01:55 PM   #8
E2 Electrician
Originally Posted by brric View Post
Move the stud.
Maybe an option.
Old 10-27-2012, 01:59 PM   #9
Thanks Stickboy, thanks Brric.
Moving the stud... is difficult. THere is an intact room on the other side of the bathroom. So the plaster wall on the opposite side is still attached!
I'm guessing both of you think notching the stud is a *bad* idea? The pancake box might be promising....
Old 10-27-2012, 02:02 PM   #10
E2 Electrician
I've notched my share of studs before, dont get me wrong, I just try to avoid it when possible.
Old 10-27-2012, 02:11 PM   #11
Semi-Pro Electro-Geek
Rewards Points: 2,942
I'd notch the stud if a pancake box didn't work for some reason. For a nonstructural wall it's no big deal.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-27-2012, 02:15 PM   #12
Rewards Points: 6,652
Two inches to the right or left is not going to matter.
Old 10-27-2012, 02:16 PM   #13
thanks mpoulton
gregzoll... are you saying appearance wise? Or functionality wise, aka, the plate will cover it?
Old 10-27-2012, 02:27 PM   #14
Master Electrician
We use pancakes all the time, much more often than I'd like. Personally if it was up to me and time is no iissue, I'd prefer to notch the stud.
Old 10-27-2012, 02:37 PM   #15
E2 Electrician
sure it will... why do you think it won't?
The Following User Says Thank You to stickboy1375 For This Useful Post:
redman88 (10-29-2012)
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
