Stuck Pull Chain Light - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2009, 08:25 AM   #1
Stuck pull chain light
Went into the closet this morning and the pull chain light in the closet was stuck. Seems like the chain is pulled all the way out (still connected) and the switch is jammed.
I know it's a simple matter to replace the fixture, but I don't want to mess with it until the weekend. Is the fixture a fire hazard in its current state?
NotSoHandyman is offline   Reply With Quote
Old 09-10-2009, 09:16 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Is it on or off?
Remove the bulb until you can replace the fixture.
If this is in a clothes closet, you need to rethink an open bulb, and put in an enclosed fixture.
Old 09-10-2009, 09:43 AM   #3
Off, but the switch is caught at the top of the toggle action, which is why I was concerned. Wasn't sure if it would spark or something.
Yeah I know an open bulb is dumb, need to see what my options are when I get to the hardware store.
Old 09-10-2009, 09:22 PM   #4
short of replacing the whole light fixture with say, a fluorescent strip light,
with a single lamp.
The size I use is 4 ft. single.
But since the lamp is operated only by the pull chain, right?
Then the Fluorscent woudl need to have a switch install on the exterior.
A good lighting store or hardware store should be able to do that for you.
If you decide to keep the pull chain porcelian, buy a compact fluorescent
bulb, use it to replace the incandescent bulb. Remember this only a short
solution.
And if the porcelain is mounted to the ceiling, you may be able to remove
the whole fixture, and install a recess light in its place. I have done that
to.
And remember a Electrician is just a phone call away should you decide
not to under take such a project.
Ranger31 is offline   Reply With Quote
Old 09-10-2009, 10:34 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
By far the easiest solution: http://www.acehardware.com/product/i...ductId=3766605
Speedy Petey is online now   Reply With Quote
Old 09-10-2009, 10:46 PM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Speedy Petey View Post
Great Find. I got a call today with a request to change out a pull chain fixture. Now I know what to do.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-10-2009, 10:49 PM   #7
Speedy Petey, good post.
I have seen that new style closet light, that appears in your post.
Most people I've talk to, don't think they give out enough light.
The MFG. may want to re-think and use a larger CPF lamp.
But give it a try, it may work for you. But keep your receipt.
Old 09-10-2009, 10:52 PM   #8
Another one on my "To Do" list - actually put lights in the closets
Most of our closets are small 4' wide with a single door that opens
So only light from the room, another light would not help
But 2nd fl knee wall storage the wife put some battery operated LED lights in
They work pretty good
I may actually plug in some LED christmas lights with an inline switch
Open bulbs are a fire & breaking hazard
Old 09-10-2009, 11:03 PM   #9
If you want safe. Then buy a big ass flashlight and then duck tape it
to the ceiling, face down. No problem.
Old 09-10-2009, 11:06 PM   #10
Until it falls & hits someone on the head
Old 09-10-2009, 11:12 PM   #11
yea, I walk right into that one
Old 09-10-2009, 11:37 PM   #12
" Euro " electrician
frenchelectrican's Avatar
I have seen that new style closet ligh, that appears in your post.
Must people I talk to, don't think they give out enough light.
IIRC they do have bigger verison you will need to swap the bulb with higher rating but I don't have the list with me at the moment but once I get the details I will post it.
Merci,Marc
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Can I use recessed light wiring for a regualr light? integrity634 Electrical 1 03-18-2009 07:29 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
My light fixture / socket question. Getson Electrical 13 02-25-2009 04:41 PM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
