Stubbing Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 12:53 PM   #1
Stubbing wires
Hi,
I am removing a non-bearing wall that has a couple lights, a couple outlets and 2 baseboard thermostat's.
I want to stub the lights and outlets in the ceiling, what is the correct way to handle this?
A junction box that is accessible and just wire nut and tape the wires?
Here is a picture of the wall you can disregard the labels.
http://i405.photobucket.com/albums/p...ouse/Wall2.jpg
PS the two thermostats will be combined into one and left above the switches there next to the vertical load bearing post.
Thanks!
mntnvew is offline   Reply With Quote
Old 01-04-2009, 01:01 PM   #2
Rewards Points: 1,514
Originally Posted by mntnvew View Post
A junction box that is accessible and just wire nut and tape the wires?!
Yes. That's all you need.
Since the wires nuts are probably too big to stay on single conductors, you will need to use tape to hold them on.
AllanJ is online now   Reply With Quote
Old 01-04-2009, 02:15 PM   #3
Thanks!
excellent thanks a lot!
Old 01-04-2009, 04:08 PM   #4
Rewards Points: 266
Please just use a smaller wire nut.
junkcollector is offline   Reply With Quote
Old 03-15-2015, 09:53 AM   #5
Licensed electrician
Rewards Points: 1,622
Agreed, if the wire nut needs tape to hold it on you have the wrong size for a single conductor.
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 08:37 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
