Stubbing Up Through Floor - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 07:24 PM   #1
Rewards Points: 152
stubbing up through floor
I'm in the process of building a wood working shop and would like to put spare conduits in the floor in case I want to move a table saw here or a planer there. I was counting on placing a 3/4" pvc conduit under grade and run a sweep up to floor level with a female adapter and a flush pipe plug at finished concrete grade.
This would give me access at a future date and not be a trip hazard if not in use. Are there any code considerations for this? Should I use a PVC sweep or a rigid sweep?
n175h is offline   Reply With Quote
Old 12-19-2012, 07:28 PM   #2
Missouri Bound's Avatar
Use the same pipe type throughout. And stub it up at least 6" or more so you have something to work with. And seal the pipe, cap it if PVC to keep construction debris out of it. Duct tape works well.
Do you want it your way or the right way?
Old 12-19-2012, 07:34 PM   #3
Rewards Points: 152
This won't work as it could be a trip hazard. I want the stubs at finished grade and if I decide to use one at a later date I can screw on a piece of conduit, mount a box and pull a circuit through the pipe and make an above ground termination in close proximity of the stationary tool.
Old 12-19-2012, 07:39 PM   #4
I'm sorry. I read you post and thought you were going to stub up at the walls. Can you just install floor boxes at these locations? You can blank them until you are ready to use them.
Old 12-19-2012, 07:45 PM   #5
Rewards Points: 320
Give yourself a little extra room and use 1" pipe in case you need multiple circuits in the future.
teamo is offline   Reply With Quote
Old 12-19-2012, 07:47 PM   #6
Rewards Points: 152
Since the AHJ classifies my project as a garage won't I run into the "wet location" status and all that encumbers about boxes buried in the floor?
Old 12-19-2012, 08:35 PM   #7
You are probably looking at GFCI's
Old 12-19-2012, 08:43 PM   #8
Rewards Points: 152
All my 120v plugs must be GFCI in this application. Seems I remember reading some code requirements for boxes in concrete requirements in a garage/shop setting, but I can't remember what is is.
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
