Strobe Lights + AFCI Circuit = Bad Combo - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 01:58 PM   #1
Rewards Points: 506
Send a message via AIM to theatretch85
Strobe Lights + AFCI circuit = Bad Combo
So last weekend I found one reason to hate the new AFCI circuit breakers in my new panel. They simply will not allow a strobe light to work (at least not at a very fast rate). I have 2 800watt strobe lights and it doesn't take much for them to trip the 20 amp AFCI circuit. Though I have found they work just fine on the 20 amp bathroom circuit that just has a GFCI outlet and no AFCI protection.
I guess this would be one of those times when the AFCI is unable to determine a bad arc from a good arc...
I don't plan on using my theatrical strobe lights in the house very often, but just something I happened to notice this weekend.
theatretch85 is offline   Reply With Quote
Old 06-09-2009, 02:08 PM   #2
DIY'r
ScottR's Avatar
Originally Posted by theatretch85 View Post
Though I have found they work just fine on the 20 amp bathroom circuit [...] just something I happened to notice this weekend.
I hate when I just "happen" to have dance parties in the bathroom. Really disrupts the ol' morning routine.
ScottR is offline   Reply With Quote
Old 06-09-2009, 02:11 PM   #3
Rewards Points: 506
Haha, it was the downstairs bathroom which is right next to the wet bar/family room area and was the only nearby outlet that was not an AFCI protected outlet (there is another in the laundry room for the washer, but that is further away). Most of the wiring in the basement is all new since I did the re-wire recently and code required several of these circuits to be AFCI.
Until last weekend I haven't had any problems with nuisance tripping of the AFCI's and see no need to change them out anytime soon, though I think my wet bar area can be changed to a standard breaker since these outlets are all GFCI's.
Old 06-09-2009, 02:14 PM   #4
1600/120 = 13A, so it's not an overcurrent condition.
I can't imagine how this is happening, but I don't doubt it is.
The lamps fire from a charged capacitor so I don't think this triggering signal is coming up the cord. Can you post a link to your strobes?
It could be a power factor problem, like you get with switching power supplies. This new AFCI design may be an attempt to fix this problem.
http://www.freepatentsonline.com/6590754.html
And, from a paper on aircraft AFCIs,
"Many standard aircraft loads and
normal operating conditions on aircraft can exhibit seemingly anomalous waveform signatures. These
can include motor start-ups, strobe lights, landing lights, bus transfers, TRU’s, incandescent and
fluorescent lighting loads, and mechanical switches opening and closing. "
Old 06-09-2009, 02:28 PM   #5
Rewards Points: 506
These are the strobes I have, I bought them for a lot less on eBay a while back: http://www.americandj.com/ProductDet...tSearch=strobe
They work ok so long as the strobe speed is set slow, but if I turn up the strobe speed too fast it trips the breaker. Both the wet bar and bath circuits are 20 amps, and both have GFCI outlets, the only difference is the wet bar circuit is protected by an AFCI breaker (and probably doesn't need to be AFCI). There is also a standard full size fridge plugged into the wet bar circuit, but it hasn't been running when trying to use the strobes (and I doubt an 800 watt strobe + fridge would trip a 20 amp circuit because of an overload).
Edit: I originally tried 2 strobes, then when that tripped the breaker I went and tried just one strobe and it still tripped the breaker.
Old 06-09-2009, 03:05 PM   #6
Seems to me a pulse rate is spec'd in the UL specification for what is a bad arc. Of course I can't find it at the moment.
An arc, being a "fourth state of matter [plasma]" is kinda' hard to pin down, I'd think.
Old 06-09-2009, 03:09 PM   #7
DIYer
The way I understand it, AFCI works by sampling the current the same way a digital scope samples a voltage, except much slower (probably khz instead of mhz). What could easily happen is the strobe light is surging lets say 50-60amps of draw every time it turns on. When the frequency of the turn-ons synchronize with the sampling rate of the AFCI, trip.... because the AFCI sees a sustained high current draw over many sample periods.
Eventually the beat patterns synchronize at some frequency multiple.
Gigs is offline   Reply With Quote
Old 06-09-2009, 03:19 PM   #8
Many people use strobes for Halloween & for Christmas displays
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Multiple lights and switches on one circuit Straightgrain Electrical 5 03-31-2009 08:34 AM
Should Ceiling lights be on separate circuit? handyoldgal Electrical 29 03-18-2009 09:54 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
