Stripping UF Cable Outer Sheath - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 03:03 PM   #1
Stripping UF cable outer sheath
What is the best method for stripping the outer sheath of 10/3 with ground UF cable with out damaging the inner conductor insulation?
Thank you
Mike2401 is offline   Reply With Quote
Old 09-16-2011, 03:21 PM   #2
They make a tool that will strip the sheath. For example: see http://www.idealindustries.com/prodD...cable_stripper
The one I have looks very different than the one in the link. About the only thing that is the same is that it is blue.
EDIT: I just noticed you specified 10/3. Here's another option: http://www.kinginnovation.com/produc...able-stripper/
The stripper I have looks closer to this one.
brgmgb is offline   Reply With Quote
The Following User Says Thank You to brgmgb For This Useful Post:
Mike2401 (09-16-2011)
Old 09-16-2011, 03:31 PM   #3
Master Electrician
Rewards Points: 3,916
Thank you
A sharp knife and a steady, light touch.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 09-16-2011, 05:22 PM   #4
Licensed electrician
Rewards Points: 1,750
It helps if the cable is warm.
Old 09-16-2011, 05:54 PM   #5
Master Electrician
The way I do it is to lightly score the outer sheath along each conductor, not scoring completely through to the conductor insulation, then peel the sheathing back on the end of the conductor enough to grasp the conductor with a pair of pliers and the pull the sheath away from the conductor.
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Color sheath on Romex/NM cable? vseven Electrical 26 01-13-2010 10:59 PM
Too much NM cable sheath inside j-box? deko Electrical 24 11-11-2009 03:27 PM
Stripping 10/3 w/gnd UF cable biker_john Electrical 1 11-07-2009 12:36 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
