Stripped Threads Meter Head - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 03:14 PM   #1
stripped threads meter head
I overtightened a meter head clamp on one of the hot wires going into my house and stripped the threads out. would it be ok to use a helicoil to repair the damaged threads? even tho the helicoil would be steel?
rustic is offline   Reply With Quote
Old 08-08-2011, 04:27 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I wouldn't. Bite the bullet and get a new meter pan and use the parts. Chalk it up as a $50 lesson.
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (08-08-2011)
Old 08-08-2011, 04:37 PM   #3
im just curious as to why you wouldnt. corrosion?
my meter box is made by milbank and they have since changed the design so i would have to change it all i believe. it is shaped like an L with a hex head bolt and now they have gone to allen head set screws.
alrighty then thanks
Old 08-08-2011, 05:35 PM   #4
Sparky
Rewards Points: 510
it wouldnt be a questions of if it would fail, but when..
Techy is offline   Reply With Quote
Old 08-08-2011, 11:16 PM   #5
" Euro " electrician
frenchelectrican's Avatar
I am on the same page as Speedy Pete with this one and I have see few meter socket lugs are damaged by overtoqured.
With alum conductors you have to be little more carefull than copper verison is and ditto with lugs if you have a toqure wrench you will see why we have to keep it from going too much due we know if too much it can do more damage with it.
Merci,
Marc
Possible Defective or Incorrect Electrical Meter? MorganB Electrical 10 01-18-2011 09:51 AM
Need to move meter socket Rustygaff Electrical 3 11-28-2010 09:44 AM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 06:00 PM
How does electricity meter calculate kwh? deerhunter Off Topic 18 09-06-2010 08:26 AM
Meter ratings Stubbie Electrical 3 04-02-2008 10:12 PM
