Old 12-26-2012, 01:36 PM   #1
Stripped Panel Screws
My house has three Siemens panels. Two @ 200 amp and one @ 100 amp generator panel. All three panels have at least one stripped panel cover screw. Any suggestions?
Thanks,
jodywoj is offline   Reply With Quote
Old 12-26-2012, 01:39 PM   #2
Not a big deal, Could just go with the next sized larger screw. Simplest way would be to use a self tapping screw.
Old 12-26-2012, 01:46 PM   #3
Thanks. The existing screws just looked a little unique. I know they should be blunt ended.
Old 12-26-2012, 02:05 PM   #4
Thanks,
The code Gawds may raise hell with this suggestion, but if you want to go for appearance using the original screws, JD weld the hole closed then re - drill and tap.
Fairview is offline   Reply With Quote
Old 12-26-2012, 04:42 PM   #5
Can you really tap threads in JB Weld?? I would not have thought so.
Old 12-26-2012, 05:03 PM   #6
The metal is so thin, i really don't think it will work.
Old 12-26-2012, 05:35 PM   #7
If this is a machine screw a nut may work if it could be JB welded to the inside using the screw for alignment and holding the nut in position until the epoxy or JB weld dries. Or a thinner piece of metal pre drilled and tapped used in the same manner. May want to apply a small amount of release agent to the screw.
Old 12-26-2012, 05:45 PM   #8
JB Weld: You can cut, drill, file, tap, machine!
Hardway is offline   Reply With Quote
Old 12-26-2012, 05:52 PM   #9
You can use clip nuts maybe!
They come in smaller sizes, just used link for an example.
http://www.oreillyauto.com/site/c/de...1766&ppt=C0142
The Following User Says Thank You to Hardway For This Useful Post:
jodywoj (12-26-2012)
Old 12-26-2012, 06:10 PM   #10
The think the clip nuts are the way to go
Old 12-26-2012, 07:59 PM   #11
" Euro " electrician
frenchelectrican's Avatar
If the 10-32 screw is stripped out then the next size you can use is 1/4-20 but you may want to tap it first.
By the way 10-32 is the same screw you will find with green grounding screw which you will see in the junction box.
Merci,
Marc
Old 12-26-2012, 08:08 PM   #12
Household Handyman
The poster was asking about the screws which hold the panel doors on. To say that the Siemens panel's door screws are "unique" would be a mis-statement, they are indeed weird. IF memory (?) serves me correctly the 200 and the 100 amp panels have six (6) screws which hold the door/cover on. IF only one screw is not tightening properly I believe that this is still within code--check local coding on this. I'm not sure about placing anything within these panels which could come loose, may be an NEC violation.
Old 12-26-2012, 08:11 PM   #13
All the Siemans panel on 200 amp size they typically come in 6 screws ( under 42 spaces ) while the 100 amp size panel typically only come with 4 screws.
The only time you may hit more than 6 screws is larger tubs like 60 space panel they will come with 8 screws or 400 amp panels and larger will have that many as well.
Merci,
Marc
Tags
panel, screw, siemens
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 06:27 PM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
