Stripped Panel Screws
My house has three Siemens panels. Two @ 200 amp and one @ 100 amp generator panel. All three panels have at least one stripped panel cover screw. Any suggestions?
Thanks, |
Not a big deal, Could just go with the next sized larger screw. Simplest way would be to use a self tapping screw.
Thanks. The existing screws just looked a little unique. I know they should be blunt ended.
The metal is so thin, i really don't think it will work.
JB Weld: You can cut, drill, file, tap, machine!:thumbsup:
You can use clip nuts maybe!
They come in smaller sizes, just used link for an example. http://www.oreillyauto.com/site/c/de...1766&ppt=C0142 |
The think the clip nuts are the way to go
If the 10-32 screw is stripped out then the next size you can use is 1/4-20 but you may want to tap it first.
By the way 10-32 is the same screw you will find with green grounding screw which you will see in the junction box. Merci, Marc |
The poster was asking about the screws which hold the panel doors on. To say that the Siemens panel's door screws are "unique" would be a mis-statement, they are indeed weird. IF memory (?) serves me correctly the 200 and the 100 amp panels have six (6) screws which hold the door/cover on. IF only one screw is not tightening properly I believe that this is still within code--check local coding on this. I'm not sure about placing anything within these panels which could come loose, may be an NEC violation.
The only time you may hit more than 6 screws is larger tubs like 60 space panel they will come with 8 screws or 400 amp panels and larger will have that many as well. Merci, Marc |
| All times are GMT -4. The time now is 06:30 AM. |
