Stray Voltage In Fiberglass Pool - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2008, 10:14 PM   #1
Unhappy
Stray Voltage in Fiberglass Pool
Can anyone suggest a interim solution while my power company here in NJ addresses an imbalance of the Neutral connection on my street. My fiberglass pool gets anywhere from 2 - 7 volts both on the metal handrail and surrounding concrete. I have no rebar and there's no metal anywhere around the pool. When the pool was installed in early 2006, a grid system was not required (it is today). When the Neutral wires are pulled from my home, the problem goes away....the Power confirms an imbalance of their neutral's but can not tell me when it will be resolved. Nobody else is complaining since there pool not fiberglass.......
Billy C is offline   Reply With Quote
Old 06-20-2008, 09:44 AM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Check out this thread.
pool "current"
I don't see that the problem was solved but hopefully it was.
I don't know of any steps you can take to mitigate a power company problem. Bonding the metal parts and even the water itself, back to your electric service panel grounding bus might solve the problem. Where is the nearest electric circuit? Pump/filter? Are you measuring the 2 to 7 volts between the water and the handrail and concrete?
John
jrclen is offline   Reply With Quote
Old 06-20-2008, 10:16 AM   #3
Tell the power company you have notified your attorney of the problem for liability purposes. That will get them moving.
BillyD is offline   Reply With Quote
Old 06-20-2008, 10:31 AM   #4
jrclen's Avatar
Rewards Points: 514
One of my neighbors called the power company to light a fire under them like that. He told them he had a life safety hazard and threatened to sue them. They sent a lineman to pull the meter and disconnect his service until they could get to fixing the problem. That way they wouldn't be liable for anyone getting injured or killed.
Some times threats can backfire.
John
Old 06-20-2008, 10:33 AM   #5
True. Be glad someone else called first. I with draw my suggestion.
Old 06-21-2008, 04:10 PM   #6
Advice worth 2 cents!
Rewards Points: 150
ok here's one...but I'd like to hear a few opinions before doing anything.
I'd suggest burying a good size copper conductor around the pool at about 24' deep and about 3' from the pool edge.
The idea comes from substation earth and fence grounding. I think that if you install a grid to provide an alternate low impedance path it might work.
-pete
---pete
HandyPete is offline   Reply With Quote
pool "current" pipefitter Electrical 60 09-20-2011 08:50 AM
Replace pool light DONRILEY Electrical 5 07-20-2008 05:51 PM
Swimming Pool Converted To Fish Pond ghall79 General DIY Discussions 6 05-23-2008 12:11 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 06:51 PM
