Stray Voltage - Commercial Application - 3PH - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2008, 02:35 PM   #1
stray voltage - commercial application - 3PH
Hi guys (and gals),
I need some help from you 3-ph experts. I have a piece of equipment at work that is causing me fits. It is a 3-ph application with motors and plc/low voltage components. I am getting stray voltage somewhere, probably from the main panel. It looks like I am getting about 25VAC from somewhere. I first noticed this when we were putting the cover on the 3-ph plug outlet box (we use plugs and flex/SO cable for alot of these small machines since the move from room to room sometimes. So far, this one has not moved), when installing the metal cover, I saw a small "static-like" spark jump from the screwdriver tip to the screw. you don't notice any indications of this unless you have worked with the machine for a while and then go across the room and touch the metal door to leave the room, where you get a pretty nice static discharge. My guess is that the 25v or so that is excess and "bleeding" into the machine somewhere is causing you to become "charged", and when you tough the door, you go to ground. Make sense? Anyhow, I didn't know if there were some "standard" places to look for small current leakages like this or not. Any advice is appreciated.
J
jeffjohnson1 is offline   Reply With Quote
Old 09-29-2008, 04:18 PM   #2
Originally Posted by jeffjohnson1 View Post
Hi guys (and gals),
No, it doesn't make sense. A static spark that you can feel is going to require at least a couple of thousand volts, not 25V, and it's going to take a DC voltage to charge you up, not AC.
Matsukaze is offline   Reply With Quote
Old 09-29-2008, 06:07 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
This doesn't exactly sound like DIY work to me.
Old 09-29-2008, 07:08 PM   #4
Rewards Points: 506
Send a message via AIM to theatretch85
I would agree, commercial setting with 3 phase power? I think this would be something better left to an electrician.
theatretch85 is offline   Reply With Quote
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Stray Voltage in Fiberglass Pool Billy C Electrical 5 06-21-2008 04:10 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
