Strange Wiring For Three Switches? - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 04:16 PM   #46
Rewards Points: 4,796
Originally Posted by tylernt View Post
Are you suggesting that a fault current of 15 to 20A can never occur?
Are you suggesting that that breakers catch all fault currents?
Enough of the nonsense. If you have something relevant and valuable to add in the context of the comments in the thread, just say it.
jeffnc is offline   Reply With Quote
Old 01-22-2013, 04:25 PM   #47
Special User
Rewards Points: 1,230
I already said it in post #41. If you disagree, just say it instead of asking nonsensical questions.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-22-2013, 04:28 PM   #48
Hardly "nonsensical". What fault current below 20 amps are you suggesting?
Old 01-24-2013, 10:32 PM   #49
Rewards Points: 240
Erm, circuit overloads happen all the time. Admittedly not as likely on a lighting circuit. But you never know when someone might decide to extend it, or use one of those old adaptors that screws into an Edison base and provides a 2-prong receptacle.
fa_f3_20 is offline   Reply With Quote
Old 01-24-2013, 10:38 PM   #50
Rewards Points: 240
Originally Posted by srtaylor View Post
The white is snipped off and not used. Picture below. From here, power goes to the light, and the neutral and black from the light returns to the original switch, but not until first powering a non-switched light. The return path is romex cable #2. Incidentally, this means, apparently, that power could enter the light from either direction???
That sounds like it might be what is called a "Carter system" or "Chicago 3-way". If that's what it is, it is an unsafe wiring method.
Old 01-25-2013, 03:46 AM   #51
Not as likely... OK, well give us an example of a circuit overload of more than 15 amps but less than 20 amps on a wire used to power a light bulb.
I already said that.
Tags
electrical switch , romex
Question on wiring two banks of lights from two switches dustycreek Electrical 3 09-09-2012 04:34 PM
Wiring switches in Ontario demandrew Electrical 4 12-14-2011 09:30 PM
Wiring multiple outlets, switches and lights Bubski27 General DIY Discussions 3 11-09-2011 06:54 AM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
strange wiring everyman Electrical 10 07-06-2009 08:38 PM
