-   -   strange wiring for three switches? (http://www.diychatroom.com/f18/strange-wiring-three-switches-169564/)
srtaylor 01-19-2013 06:11 PM
1 Attachment(s)
Can someone please help me understand what in the world is going on in this pic? 7 cables (all 12/2 Romex) entering a three switch box. The switch in the middle is a 3 way switch. I understand the wiring basics, but this one goes a little beyond me. Also, the triangles represent wire nuts or equivalent.
Much obliged for any light you can shed!
Stephen
oh'mike 01-19-2013 06:16 PM
Post a photo---your drawing is incorrect. (I think)
srtaylor 01-19-2013 06:25 PM
1 Attachment(s)
Pic attached. Rechecking the diagram.
gregzoll 01-19-2013 06:29 PM
Everything looks fine to me. You have a common Hot, and the Neutrals are all tied together, even though you have two single poles, and a 3-way. So again, what is your question, and are you having some kind of issue with the way it has been hooked up for quit some time?
srtaylor 01-19-2013 06:29 PM
1 Attachment(s)
Better pic
rjniles 01-19-2013 06:30 PM
I assume dark wire/triangle is black wires and dotted is white.
1 of the 12/2s brings hot and neutral into the box, the hot is pigtailed and looped the the upper terminals of all three switches. All the neutrals are tied together.
2 of the 12/2 feed the switched hot and neutral to a light or other device. The 2 single pole switches in either end of the box.
1 of the 12/2 is the travelers from the 3 way watch to the 3 way at another location.
The last 3 of the 12/2s feed unswiched hot and neutral to switches and/or receptacles at other locations.
rjniles 01-19-2013 06:37 PM
I will add that the 3 way is wired in a noncompliant manner. The cable going to from the 3 way switch to the other 3 way should be a 3 wire cable to include a neutral.
fa_f3_20 01-19-2013 06:37 PM
Something is not right with that 3-way. It doesn't appear to have a neutral.
srtaylor 01-19-2013 06:44 PM
I don't understand how the three way switch in the middle works...I thought I needed. 12/3.
What would it take to make it compliant?
gregzoll 01-19-2013 06:56 PM
Go back and look again. That white on the lower left is the Neutral/Common. It is just that the Travelers are both black. There is no ground showing though, that would be a problem with today's standards if they make any changes to the circuits.
rjniles 01-19-2013 07:06 PM
re the 3 way. They are using the black and white of a 12/2 as trsvelers and picking up a neutral at the far end. Not kosher.
Gac66610 01-19-2013 07:11 PM
Looks okay to me.
Probably a two wire feed and traveler, switch leg is at the other switch.
So both switches have neutrals, but as old as that work looks, neutrals would not have been needed, code compliant when built.
Use to be quite common.
srtaylor 01-19-2013 07:17 PM
Helpful comments. Thank you, everyone. I would like to turn the switch on the right into a 3-way switch. Easy enough for me to replace the furthest right romex with 12/3 for running it to the rest of that circuit. Technically, does messing with that switch mean I need to rewire anything else?
joed 01-19-2013 09:04 PM
To make the right switch a three way is simple once you get the cable to the new switch. You need a 12/3 cable to the new switch.
I am going to skip ground wires in the description. Connect all of them together and to the switch if it has a ground screw.
Remove the two black wires from the existing switch. Leave everything else alone.
Connect one black wire to the common screw of your new three way switch#1.
Connect the other black wire to the black wire to your new switch#2 cable.
Connect the red and white wires to the remaining two traveller screws of the new switch#1.
At new switch#2 connect the black to the common screw.
Connect the red and white wires to the remaining two traveller screws of the new switch#2.
srtaylor 01-19-2013 09:29 PM
Originally Posted by joed
To make the right switch a three way is simple once you get the cable to the new switch. You need a 12/3 cable to the new switch..
I assume 14/3 is also an option?
