Strange Power Situation - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 10:54 PM   #1
Angry
Strange power situation
In the past year we have replaced our 25 yr old geothermal heat pump with a new energy effecient one, installed energy effecient freezer, washer, dryer, refrig, energy effecient bulbs and installed an on demand elec water heater. OUR KW HOURS HAVE GONE UP BY 1/3.
called the power company and they say that they reread our meter and it is correct. ny ideA ON WHAT COULD BE CAUSING THIS?
pearl1ben is offline   Reply With Quote
Old 08-17-2009, 01:19 AM   #2
Rewards Points: 2,350
Those on demand water heaters can be a real power hog. Maybe you are taking longer showers because you have unlimited hot water? Go take a look at your meter while the hot water is running and see how fast the meter is spinning.
Old 08-17-2009, 07:27 AM   #3
DIYer
The geothermal heat pump might have been considerably more efficient than a standard air-air heat pump... are you still using the geothermal loop?
Gigs is offline   Reply With Quote
Old 08-17-2009, 07:28 AM   #4
Do you have a well pump?
Old 08-17-2009, 07:50 AM   #5
No. The only exterior electrical usage is a 240 volt 60 amp spa which has been in use for 5 years.
On second thought there is a well pump that supplies the geothermal heat pump.
Old 08-17-2009, 07:52 AM   #6
Not using a loop. The heat pump is a much newer version of the original heat pump.
Old 08-17-2009, 09:47 AM   #7
Electrical Contractor
kbsparky's Avatar
Have you installed a plasma TV? Those are energy hogs ....
-KB
Old 08-17-2009, 10:13 AM   #8
Yes, we have put in a 50" and 30" plasma tv.
Old 08-17-2009, 10:32 AM   #9
DIYer
50 inch is about 500 watts. Do you run them all the time?
Old 08-17-2009, 10:48 AM   #10
The 50" runs about 9 hrs a day and the 30" about 4 hrs.
Old 08-17-2009, 11:08 AM   #11
Rewards Points: 126
I would put my money on the water heater. How many double pole breakers did you have to install. Whole house demand WH's do not save any money. You have to add the cost of installation too, and you haven't even done that yet. IMO they cost more to run and recouping the installation cost may never be realized. I would cut the temp setting down as low as possible and use the least amount of hot water as you can. Tells us the KW of the WH. That would be an a good indicator.
Old 08-17-2009, 01:10 PM   #12
DIYer
That's not enough to explain a 1/3 increase in whole house usage, but that is a good 5khw per day or so... lets say $15 per month or so.
Change from plasma to LCD and you'll save a lot of money in the long run.
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
Strange electrical power situation Richo Electrical 8 12-11-2008 07:06 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
