Strange Power Issue In The Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 09:19 PM   #1
Rewards Points: 337
strange power issue in the garage
So we are in a remodel, have the frig, two wine coolers and the Garage door opener plugged into one of the 20amp circuits in the garage as the inside of the house is being worked on. It's been this way for a few months no issues. Tonight my wife opens the garage door, and the garage door opener light starts flickering, she called me down to look, we also opened the frig door and the interior frig light is flickering also, same timing as the garage opener light flickering. So I go to the panel, the circuit did not trip. I tripped it off, when I turned it back on I hear a slight buzzing sound for about a second. Still having the flickering, so I decided to turn it off until we get the electrican out here. Any ideas???? Very strange.
titan7 is offline   Reply With Quote
Old 04-05-2011, 09:24 PM   #2
" Euro " electrician
frenchelectrican's Avatar
The way you descibing you may have loose connection at the breaker termail or a bad bussbar connection which it may burnt the bussbar connection.
The best thing you can do for now is turn it off and for the fridge if anything is crictail run a extendison cord to diffrent circuit in the garage or in the house. otherwise the fridge will not hurt at all as long you don't open the door they can stay cold up to 7 hours depending on the tempture in the garage.
Is this garage is attached or detached garage ?
Merci,
Marc
Old 04-05-2011, 09:41 PM   #3
Rewards Points: 337
Yes, the garage is attached.
Old 04-07-2011, 01:15 AM   #4
Did the electrician come by and check it out yet?
Most likey you may have loose connection or bad bussbar or bad breaker one of the three or some case it can be combo of two which I have see it from time to time.
Merci,
Marc
Old 04-07-2011, 10:44 AM   #5
Rewards Points: 337
Thanks frenchelectrican!
Yes they came by yesterday, bad breaker the plastic was cracked where it snaps in which caused a loose connection on the buss bar, they replaced the breaker and cleaned the connections. All good!
Thanks for your help!!
Craftsman 1/2hp Garage Door Opener No Power DIYfer General DIY Discussions 4 09-11-2011 09:02 AM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 02:38 PM
Dryer with no heat/House power issue Raygun Electrical 15 03-03-2010 11:26 AM
Strange power situation pearl1ben Electrical 11 08-17-2009 01:10 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
