Strange Colored Wiring On Old Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 02:57 PM   #1
Strange colored wiring on old light switch
I'm replacing a simple light switch with a timer switch. I've done a few of these in the past but I'm definitely not particularly experienced in this area.
The box only has one light switch in there with a total of 4 wires coming into the box. I have 2 wires going to 2 screws on the old light switch. One is black and the other is white but with some colored tape. (from research I've done it seems that it can still be code to use a hot white wire as long as there's colored tape on the wire.) There is also a bare ground wire going to the switch. In addition I have an unused single red wire that is just capped off.
The timer I'm trying to install requires a neutral wire. Considering that the white wire is hot (probably the load wire) is it possible that the red capped wire is actually neutral? Or is it just another hot wire sitting there doing nothing. Keep in mind that this is the only switch at this box though it is wide enough for 2.
NYHeel is offline   Reply With Quote
Old 07-25-2012, 03:20 PM   #2
Licensed electrician
Rewards Points: 1,296
The red should not be a neutral. I suspect someone roughed in wiring for 2 switches like for a light and a ceiling fan.
Old 07-25-2012, 05:10 PM   #3
"So I Re-Wired It"
MisterZ's Avatar
If im understanding you right, there is only one set of wires coming to tje switch plate
Such as 14/3 (black, white, red, and ground grouped together)
If this is true, there is no neutral in that box. One set of wires goes from the fixture to the switch.
Black being constant hot to switch, white carries current to the black at fixture. (Hot when switch is in ON position.
In this scenerio the red should have been used instead of white.
Without seeing and checking wires its hard to know for certain.
Hope this helps
MisterZ is offline   Reply With Quote
Old 07-25-2012, 05:55 PM   #4
Thanks. I figured the red wasn't neutral but I just wanted to confirm. I'll get a timer that doesn't require a neutral wire.
Old 07-26-2012, 01:51 PM   #5
If that 3wire goes up to the fixture, re jigger it to bring the neutral down on the white and use the red as the switch leg.
Evstarr is offline   Reply With Quote
Tags
light switch , neutral wire , timer , white wire
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 07:27 AM
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 11:51 AM
Wiring an outlet to a switch, to a light Athens Electrical 5 01-04-2012 08:03 PM
Light Wiring Question mataguri Electrical 4 11-09-2011 03:15 AM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
