Strange 3 Way Switch Loop - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 07:22 AM   #16
Rewards Points: 2,516
Originally Posted by hammerthro View Post
All the diagrams that I have found show the red wire running through the fixture. Does this make any sense? Any help would be greatly appreciated. Thanks.
I believe this diagram is somewhere on this site. We should ask the moderator to make an electrical subtopic call Three Way
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
hammerthro (07-14-2012)
Old 07-14-2012, 11:09 AM   #17
Thanks for the diagram. That is pretty much what I did except I ran the black power in to the black switch wire. The white switch wire became the switched hot. I hooked up a light to it and it worked like a champ. Any concerns? Thanks for all the help.
hammerthro is offline   Reply With Quote
Old 07-14-2012, 11:11 AM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What you did was incorrect, you can't have two whites at a fixture, change the splice.
Old 07-14-2012, 12:07 PM   #19
What is the problem with 2 whites at a fixture? Is is that code says you can't or is there a safety issue?
Old 07-14-2012, 12:38 PM   #20
Code says the white wire cannot be used as the return conductor in a switch loop.
200.7 Use of Insulation of a White or Gray Color or with Three Continuous White Stripes.
(2) Where a cable assembly contains an insulated conductor for single-pole, 3-way or 4-way switch loops and the conductor with white or gray insulation or a marking of three continuous white stripes is used for the supply to the switch but not as a return conductor from the switch to the switched outlet. In these applications, the conductor with white or gray insulation or with three continuous white stripes shall be permanently reidentified to indicate its use by painting or other effective means at its terminations and at each location where the conductor is visible and accessible.
Old 07-14-2012, 01:03 PM   #21
If I switch them, should it still work, or being that is how it was originally wired, should I leave good enough alone?
Old 07-14-2012, 03:52 PM   #22
Sparky
Rewards Points: 510
It's only a technical violation, it will work in practice correctly.
Electricity doesn't care what color the insulation is
It is still a violation, though.
Techy is offline   Reply With Quote
Old 07-14-2012, 06:16 PM   #23
Thanks Techy, that is what I needed to know.
Old 07-14-2012, 06:17 PM   #24
E2 Electrician
Seriously, it will take you less than 5 mins to correct the issue...
Old 07-14-2012, 10:02 PM   #25
Master Electrician
Take the black and white and flip them. Easy fix
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-14-2012, 10:58 PM   #26
So then, my question again, do I need to change wires at the switch or just at the fixture?
Old 07-14-2012, 11:44 PM   #27
Master Electrician
take the black going to the switch out of the wirenut and put the white there and put black tape on it and take the black from the switch to the light. It'll save you a ton of trouble if you ever have to troubleshoot it down the road.
The Following User Says Thank You to andrew79 For This Useful Post:
hammerthro (07-15-2012)
Old 07-15-2012, 05:08 PM   #28
Thanks Andrew, will do.
adding a light and switch .. using a switch loop?? beachfront71 Electrical 14 03-28-2012 08:26 PM
Strange pressure switch problem jones814 HVAC 24 01-16-2012 10:24 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
switch loop aokss Electrical 13 05-07-2007 08:41 PM
