Old 08-20-2012, 08:39 PM   #1
stranded wire gauge 2 in neutral/ground bus
Is it OK to separate only 1-2 of the about 6 stranded individual threads for fitting into a small hole in the neutral and ground bus bars because all of them won't fit?
or are there adapters you can get that fit in where the screw goes but the hole is bigger to receive a fatter wire (my guts tell me this is the solution)?
This is for a 100A subpanel
Old 08-20-2012, 09:02 PM   #2
Lic Electrical Inspector
electures's Avatar
There is a terminal made for it and it has to be used.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
amakarevic (08-20-2012)
Old 08-20-2012, 09:06 PM   #3
do you know what it is called? i wanna check online
Old 08-20-2012, 09:22 PM   #4
E2 Electrician
stickboy1375's Avatar
look at the panel specs, every item available is listed for each panel.
You need something like this, but... it MUST be listed for type of conductor you are landing, grounded, or grounding type conductor.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
amakarevic (08-20-2012), electures (08-24-2012)
Old 08-20-2012, 09:49 PM   #5
i am using gauge 2 AL cable with 2 hots, 1 neutral and a ground. the ground is skinnier than the rest. i checked and AL is OK in my municipality for feeding a subpanel. some old cables in the house, probably from before WW2, are also AL
Old 08-20-2012, 09:51 PM   #6
E2 Electrician
The problem is, the lug I posted us usually only good for a grounding conductor....
Old 08-20-2012, 09:54 PM   #7
i will go to the local elec supply store tomorrow, i am sure they will have what i need.
thanks
Old 08-20-2012, 10:35 PM   #8
Master Electrician
I have to ask, are you ever going to finish this reno. I just went back and took a look at the threads you've started. You've been installing panels and building appartments since 2008. You do know this site is for diy right. Not DIY handyman for other people. No offense intended if it actually is for your own use, but I for one don't aprreciate being someone's sounding board that's doing electrical work for other people illegally if that happens to be the case.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-20-2012, 10:50 PM   #9
Master Electrician
As I said no offense intended. You took on a big project then. I think ill stick around and read your posts still. I'm curious as to if that panel in the half wall passes inspection.
Best of luck with your reno.
Old 08-21-2012, 05:59 AM   #10
Electrical Contractor
kbsparky's Avatar
... some old cables in the house, probably from before WW2, are also AL
If they are that old, they are probably NOT aluminum. More likely they are tinned copper.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
brric (08-21-2012)
Old 08-21-2012, 03:15 PM   #11
I got this at HD but it's called "neutral lug kit" even though it looks like there is no reason you couldn't fit ground in it too.
stranded wire gauge 2 in neutral/ground bus-forumrunner_20120821_151528.jpg
Old 08-21-2012, 03:59 PM   #12
Thats only rated for 70 amps!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
amakarevic (08-21-2012)
Old 08-21-2012, 05:11 PM   #13
Master Electrician
I don't get it. There should be a hole in the ground bar large enough to accept the wire. Usually its on the top of the bar and feeds a different direction. Same with the neutral bar. It should have a larger lug on the top too. Is like to see a pic of the guts of the panel if possible. Somethings not adding up. You shouldn't have to buy anything.
Old 08-21-2012, 05:32 PM   #14
there is only one big one and that is for the incoming wire. but on the main panel you have an incoming big wire from the meter (not sure what gauge but certainly fat) and then there is a big out wire for the subpanel, gauge 2. applies both for neutral AND ground. so i do need two fat adapters rated for 100A.
Old 08-21-2012, 05:58 PM   #15
Master Electrician
try this out, it screws into the existing screw hole. most likely ul listed if it's sold at sears.
http://www.sears.com/square-d-100a-h...SPM6549038701P
The Following User Says Thank You to andrew79 For This Useful Post:
Wire Gauge and Circuit Breakers Red Truck Electrical 21 01-21-2012 07:33 AM
What size ground wire should I use for 8 gauge power dxmullin Electrical 1 07-06-2011 03:57 PM
Wire Gauge for 30A RV Outlet (long span) jayne1986 Electrical 24 02-20-2011 09:18 PM
My 12 gauge wire fiasco, overkill needing removal ChrisDIY Electrical 8 01-25-2011 07:47 PM
connecting straight wire to stranded Cossack Electrical 5 07-30-2010 02:52 PM
