Stranded Wire Connections - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2008, 08:59 PM   #1
Rewards Points: 150
Stranded wire connections
I just bought a new Kenmore stove for the kitchen. The wires are just stranded like for a chandelier. I ran 6 gauge cable with a 50 amp breaker to the stove for power.
What is the secret to joining this stranded wire to such big wires? For that matter, is there any trick to joining regular 14 gauge wire to stranded wire for lights?
Cossack is offline   Reply With Quote
Old 03-13-2008, 09:29 PM   #2
Idiot Emeritus
Rewards Points: 1,492
The stove likely has #10 stranded. Usually, a finer strand than building wire.
For something like this, I usually use the big blue wirenuts. Using your fingers (not pliers), twist the fine strands tight. Then, put the two wires side-by-side (no need to twist these together), make the smaller one stick out past the bigger one by about 1/16", put the wirenut on, and twist it as tight as you can with your hands. Then grab the wirenut with one hand, and try to pull each wire out with the other hand. If you can't, you've made a good splice.
When joining stranded to solid, make the stranded stick out past the solid slightly. When thghtening the wirenut, the stranded tends to twist around the solid, and 'leading' it a bit insures that all the strands get under the spring part of the wirenut.
Rob
micromind is offline   Reply With Quote
Old 03-13-2008, 09:34 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Did you run 3 wire or 4 wire cable for the branch circuit to the stove/range?
Old 03-13-2008, 10:56 PM   #4
Blue nuts and massive forearms
The first thing is to cut the wires the same length. Strip them about an inch. Make sure the ends are almost even with the smaller wire a touch longer. The CRITICAL step is to hold the wires TIGHTLY between your thumb/finger as you press/twist the nut on. One of the wires will tend to push out if you don't hold them tightly. Once you get them snug you can carefully twist another turn with channel locks if you don't have the massive forarms. Don't over do it and compromise the plastic. Make sure there is no copper showing at the bottom of the nut.
Try and pull the wires one at a time from the nut. If it comes out, you didn't do it right.
220/221 is offline   Reply With Quote
Old 03-14-2008, 07:01 PM   #5
Rewards Points: 150
The cable I am bringing in is 6 gauge with a black, red, white, and neutral wire .
Old 03-14-2008, 07:08 PM   #6
Rewards Points: 150
So I do not twist the wire before I put on the wire nut on?
Old 03-14-2008, 08:03 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
That would be black,red,white(neutral) and the equipment ground wire
Good that you ran 4 wires.
I'm still a little confused if you have a range with oven or a cooktop stove. Can you verify which you have? It would be a little odd for a range to have connection via an appliance whip like your describing. And it would also be odd that a cooktop needs a 50 amp circuit.
Can you give us the model# of the stove?
Old 03-14-2008, 10:56 PM   #8
Correct. Just place them side by side.
Stranded wire doesn't like to pre twist. It will twist inside the nut.
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 06:37 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
