Old 11-08-2012, 10:56 PM   #1
Stranded or solid wire
I am in the process of I stalling a new 30a DP breaker in my panel and attaching that to a 30a inlet receptacle ia 10g wire for my back up 6500kw generator to plug into. Now most of you experienced members might laugh at this but I am not experienced and am posting here because I am a DIY homeowner.
I asked the senior electrical guy ( who is also a teacher of electrical at the local college) at home depot for some assistance with cutting me my 10g wires and he cut 3 feet of red. Black. Green and white for me. But it appears to be stranded wire not solid. He knew what this was for and still cut that. Is this bad and or gonna be a safety issue for my panel and or generator?
I am planning on installing this receptacle tmrw and wiring it up....obviously before I do that I wanted to check in with the members and get some feedback.
Thanks.
Greenie is offline   Reply With Quote
Old 11-08-2012, 10:58 PM   #2
Electrical Contractor
Stranded is fine.
Is this to be used inside the panel?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-08-2012, 11:08 PM   #3
Originally Posted by jbfan
Stranded is fine.
Yes. There's now a 30a breaker in that empty spot waiting to be wired up
Old 11-09-2012, 01:19 AM   #4
Send a message via AIM to theatretch85
If this is for a generator back-feed you MUST install an interlock kit to prevent the main breaker and the generator breaker from being on at the same time.
theatretch85 is offline   Reply With Quote
Old 11-09-2012, 01:42 AM   #5
I know and did. Wasn't inquiring about that. Only about the stranded vs solid wires.
Old 11-09-2012, 06:07 AM   #6
kbsparky's Avatar
Stranded wire is preferred over solid in such an installation.
-KB
Old 11-09-2012, 07:13 AM   #7
A "Handy Husband"
rjniles's Avatar
KB,
Is that a personal preference or is there a compliance issue?
Poster,
? The 40 amp breaker below your empty slot. What does that feed? It does not look like #8 wire.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 11-09-2012, 07:26 AM   #8
Licensed Electrician
k_buz's Avatar
Originally Posted by rjniles View Post
KB,
No code issue, and with #10 and up, I think most if not all electricians prefer stranded over solid. Its really only with #14 or #12 do you have the big debate.
Location...Location...Location
Old 11-09-2012, 08:05 AM   #9
kbsparky's Avatar
KB,
Is that a personal preference or is there a compliance issue?.....
Personal preference. When terminating a #10 wire into those flanged inlets, a stranded wire makes for a much better connection than that stiff #10 solid.
I have had the solid wire twist loose when manipulating the inlet after tightening the connection. Never happens with a stranded conductor.
-KB
Old 11-09-2012, 09:48 AM   #10
KB,
Poster,
It's a 40a DP quad breaker. 1 set feeds the 4 ton AC compressor and the other set feeds a sub panel that runs the tankless water heater and the washing machine/dryer.
Old 11-09-2012, 01:55 PM   #11
that 40 amp below vac space is not a 2 pole quad.it is just a bouble pole 40 amp.
oleguy74 is offline   Reply With Quote
Old 11-09-2012, 04:00 PM   #12
You need guidence from an experienced electrician on how to install a generator panel.
bobelectric is offline   Reply With Quote
Old 11-09-2012, 04:58 PM   #13
Sorry. Dumb that down for me? What's a bouble ?
Old 11-09-2012, 05:03 PM   #14
doubble pole.two breakers rivetted together with a handel tie.quad breaker is two single pole two handel breakers riveted together.giving a 240 volt ckt and two sinhle pole ckts,or two 240 volt ckts.the two breakers at left of the vac spot are tandems.
Old 11-09-2012, 05:07 PM   #15
Licensed Electrical Cont.
Speedy Petey's Avatar
Doesn't matter what you are inquiring about. He was correct in making that statement, just to be sure.
Best practices for splicing stranded to solid wire sixspeed Electrical 13 09-30-2012 02:46 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Stranded wire in breaker? gma2rjc Electrical 3 09-25-2010 01:00 PM
connecting straight wire to stranded Cossack Electrical 5 07-30-2010 02:52 PM
6/3 NM stranded or solid to run to 50A subpanel amakarevic Electrical 5 10-31-2008 01:14 PM
