Stove Wiring - 3 Wires In Wall No Red - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2009, 07:49 AM   #1
skd
Question
Stove wiring - 3 wires in wall no red
Hi,
I am moving into a house that had a dryer outlet where the stove is supposed to go. As far as I know no dryer was ever installed there. The double breaker is 60 amp.
I removed the outlet cover and found 3 wires : white, black , bare, but no red!
How do I make it work so I can plug my stove?
(The stove is a newer one and has a 4 prong cord , but I can change that if needed)
Thanks for your help!
skd is offline   Reply With Quote
Old 05-08-2009, 08:54 AM   #2
Licensed Pro
Originally Posted by skd View Post
Hi,
The only way to properly wire this for the stove is to replace the wiring with 6/3 w/g cable and replace the breaker with a 50A. (Alternatively you could use 8/3 and 40A). The white/black/bare has never been an acceptable way to wire a stove (or dryer).
Old 05-08-2009, 10:09 AM   #3
DIY = Done Right 1st Time
What is the neutral wire there for in 4-wire installs?
BowDown is offline   Reply With Quote
Old 05-08-2009, 11:44 AM   #4
Licensed electrician
Rewards Points: 1,020
It returns the neutral current from the control circuits and light bulbs.
Old 05-08-2009, 11:46 AM   #5
Gotcha so it basically provides the appliance with 240v and 120v...
Old 05-08-2009, 12:02 PM   #6
Rewards Points: 58
Dryers and ranges are rated 120/240. That is why you have a neutral. Even though the range may operate without one, it is required in NEW installations.
Old 05-08-2009, 04:41 PM   #7
Your dryer must be on a 30 amp breaker. The existing wire is technically not proper for a range or a dryer. Type SE cable has a bare ground/neutral and is acceptable. Type NM is just about the same thing but its not legal.
Personally, if it was in my place, I wouldn't hesitate to use it. If I was doing any renovation work, I would replace it and make it legal.
If you do change to a 3 wire pigtail on your range, be sure the bonding strap in in place. It ties the center terminal (the bare neutral/ground) to the metal frame.
Even though the range may operate without one, it is required.
In new installations.
Existing can use the 3 wire system.
220/221 is offline   Reply With Quote
Old 05-08-2009, 05:54 PM   #8
Rewards Points: 2,350
Except the fact that the bare neutral in type SE cable is the same size (or almost) as the circuit conductors.
Old 05-08-2009, 07:44 PM   #9
True but, how much current does it carry?
To me, the dangerous part is the possibility of the appliance carrying current if the neutral/ground opens. That could happen with any 3wire installation.
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 10:24 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Removal of interior wall Bobb G Remodeling 4 09-15-2008 02:30 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
