Stove Shorts When Plugging In - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2011, 11:05 AM   #1
Stove shorts when plugging in
Having a really bizarre issue, I'm completely baffled.
- High rise condo built in 2003. So conduits/BX used extensively.
- Renovating the kitchen. Moved a light switch, added a plug, nothing major. Did NOT touch the stove circuit.
- Stove circuit was hot and had no problems.
- Plugged in stove. Tripped the unit MAIN breaker. 40's not tripped.
- Checked the 240 outlet. Looks like some nicked wires, so taped them all up.
- Turn off 40's, engage the main breaker. Stove is plugged in. Try to reset the 40's... trips the main again.
Stove is brand new, so I'm considering it's faulty, but that's like a 1 in 1000 chance probably.
Main questions
1) How can the circuit be hot and not trip the breaker?
2) Why isn't my 40A breaker going? Why does the main keep tripping?
3) What are my steps to troubleshooting?
Thanks!!
enkoopa is offline   Reply With Quote
Old 05-08-2011, 11:15 AM   #2
I=E/R
a7ecorsair's Avatar
Main questions
Thanks!!
What do you mean the stove is brand new? Did it work before you started working on the kitchen?
Your main could trip first because of the existing load that is on the panel before you connect the stove.
If this is a new stove, who wired it and is it cord and plug or direct wiring?
a7ecorsair is offline   Reply With Quote
Old 05-08-2011, 11:16 AM   #3
maybe the 40 has gone bad and is shorting to the main. good sparkies on this site will br along for more insight
The older I get the better I was
Old 05-08-2011, 11:19 AM   #4
Mad Scientist
If the breaker doesn't trip unless the stove is plugged in, odds are good that the problem is in the stove. If the breaker trips immediately, it sounds like there's a dead short in the stove. I'd start by checking the terminals where the cord is attached to the stove.
As for the main tripping instead of the 40A stove breaker, that's just the way it goes sometimes. Under a dead short, there might be maybe 10,000A flowing for a millisecond or two. It's essentially random which breaker along the path will trip.
McSteve is offline   Reply With Quote
Old 05-08-2011, 11:26 AM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I would expect the 40 to trip first but unless you are dealing with brand new breakers, all bets are off. While all major manufacturers recommend you exercise your breakers annually, I have yet to meet a person (other than myself) that does so. That can allow a breaker to become stiff and not trip as designed.
The 40 amp breaker could be bad as well and just not tripping as it should.
If the stove is brand new and no work was done to the receptacle or it's wiring, I would suspect it is the stove. (given that receptacle worked before).
If you have a continuity tester, I would start with checking for a short in the appliance by checking for continuity from ground to each of the "hots" and the neutral at the plug. You should have no continuity from ground to anything else.
Old 05-08-2011, 11:32 AM   #6
We didn't want the appliances when we bought it so the previous owner took them. One would assume the stove was in a working state.
So brand new stove, it has a plug, came that way. I'll test the continuity on the plug and report back.
The wire is likely 8-3? Or would it be 8-4? I can only imagine having to fish a new one of those, they must be stiff as hell. I'm in North America, I'm assuming it will still be BX (armored) cable that has to be run in the conduit?
I'm trying to ease my mind that I didn't nail/drill/something the stove circuit while working on the kitchen - but surely, that would have tripped the breaker without any load on the circuit.
Old 05-08-2011, 11:38 AM   #7
I=E/R
a7ecorsair's Avatar
So, this new stove has never worked and it has a plug. Who installed the line cord on the stove? Does the line cord have 4 prongs? The cord could be connected incorrectly to the stove.
Old 05-08-2011, 11:44 AM   #8
It was delivered with it attached. I would assume it comes like that from Whirlpool? Or did the appliance company do it?
I'm quite sure it was 4-prong.
Old 05-08-2011, 11:53 AM   #9
I=E/R
a7ecorsair's Avatar
The cord was most likely added by the dealer. That would be the first place to look for trouble.
Old 05-08-2011, 06:45 PM   #10
Yup, the stove has a short sure enough Thank god!
Old 05-08-2011, 07:10 PM   #11
I=E/R
a7ecorsair's Avatar
Was the cord connected wrong inside the range?
The Following User Says Thank You to a7ecorsair For This Useful Post:
enkoopa (05-10-2011)
Old 05-10-2011, 08:25 PM   #12
Nope, it was fine. So he came today and opened it up.
There's 4 screws that hold the main control panel to the frame. One of those was piercing one of the wires Right from the factory.
So.. what are the odds? Guess I should buy a lotto ticket.
Old 05-10-2011, 08:53 PM   #13
I=E/R
a7ecorsair's Avatar
Thanks for the closing post. It is always nice to hear the final outcome
Old 05-10-2011, 10:47 PM   #14
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
as as appliance repair tech this kind of piqued my curiousity, can one of you electricians explain to me why his main breaker was tripping and not his range circuit breaker. I have never seen a short in a range trip the main breaker.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-10-2011, 11:11 PM   #15
I=E/R
a7ecorsair's Avatar
One possibility would be that the main panel already had a heavy load for what ever may have been active in the house and the short caused a surge that put it over the top and the main just responded faster than the stove breaker.
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 10:30 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
