Stove Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 11:00 AM   #1
Rewards Points: 87
stove plug
I moved the stove plug to a different spot in the kitchen. Its a three prong plug with white,red,and black wires. One terminal says white, does it matter which one is black and which is red?
Roundeye is offline   Reply With Quote
Old 09-22-2011, 11:21 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
No. It doesn't matter.
Old 09-22-2011, 07:54 PM   #3
Rewards Points: 150
I haven't done any resi work yet, but I didn't know that a stove needed a neutral. Huh, learn something new every day
Sunny B. is offline   Reply With Quote
Old 09-22-2011, 08:37 PM   #4
I=E/R
a7ecorsair's Avatar
So does an electric dryer
a7ecorsair is offline   Reply With Quote
Old 09-22-2011, 08:55 PM   #5
Missouri Bound's Avatar
No matter how much you know, there is twice as much to learn. Most modern appliances require 120 / 240. The controllers are electronic now, rather than mechanical and they require a 120v circuit.
Old 09-23-2011, 01:28 AM   #6
" Euro " electrician
frenchelectrican's Avatar
The only gotcha you will have to deal is once you move the stove plug I know the old one is three wire but once you relocated to diffrent spot it have to be four wire plug not the three wire plug any more.
Merci,
Marc
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Extending Range Of Stove Electrical - bad idea? sleepysmurf Electrical 33 08-10-2010 09:30 AM
Need help. Weird problem with stove plug. latinomusician Electrical 10 06-20-2010 09:20 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
