Stove House Wiring. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 12:16 AM   #1
stove house wiring.
I just removed a stove with a 3 prong outlet and plug and the new stove is 4 prong. The wire from the panel id 3 wire. 2 hots and a neutral. I know that I need a ground wire for new plug. There is a very long run from the mail panel to the stove outlet. This is my thought. Could I not use the old stove wire, running from the main panel and use it to set up a sub panel in the basement, below the kitchen stove area. To set up a sub panel the neutral and the ground are attached to the ground/neutral bus bar but separated at the sub panel. Could I not use the 3 wire as 2 hots and neutral and just runner a single wire from the main panel, to use as a ground into the sub panel, instead of doing the whole length with a new 4 wire?
Ron-NY is offline   Reply With Quote
Old 12-12-2011, 12:51 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,852
The easy and normal thing to do is to replace the 4-wire cord with a 3-wire cord, being sure to bond the neutral and ground terminals in the appliance according to the instructions. This is allowable.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
gregzoll (12-12-2011), Ron-NY (12-12-2011)
Old 12-12-2011, 01:01 AM   #3
Oh...I did not realize that that was an option. I purchased this stove, with the 4 wire plug used, so I don't have a set of instructions but I am sure with a bit of googling I can find the instructions for it. Thank you! This is going to be easier than I thought. lol
Old 12-12-2011, 08:33 AM   #4
Rewards Points: 6,652
You do not have to google anything. mPoulton stated exactly what needs to be done on the stove. Unhook the 4-wire plug, take the green wire that is hanging free place back on the chassis, and then attach the green screw back above the white wire.
Even easier, just post a picture of the wiring block, and we can tell you how to do it. There are other posts about the exact same thing, but the opposite way, going from 3 to 4, you just reverse the process.
The Following User Says Thank You to gregzoll For This Useful Post:
Ron-NY (12-12-2011)
Old 12-12-2011, 08:49 PM   #5
I thank you both. I will open the the unit tomorrow. Take the 3 prong plug from the old stove and attempt this. Funny, I have done my own house wiring for 25 years...took this whole building that had 100amp fuse box and very few outlets and rewired the whole place adding a 200 amp panel yet have no idea about appliances...lol I did see the other threads but didn't know the reverse was safe or not. If I have a problem I will post pics but I think I should be able to accomplish this. Again, thank you!!!
Old 12-12-2011, 09:23 PM   #6
Here Ron, is some info in how it should be hooked up, either 3-wire or 4-wire.
Ron-NY (12-12-2011)
Old 12-12-2011, 09:47 PM   #7
WOW...you guys are great!!!! Thanks!
Hot tub wiring from main house robmet1015 Electrical 8 08-02-2011 09:22 AM
Wiring Help, Changing a Dryer and/or Stove circuit to something else shunut Electrical 10 01-08-2011 04:06 PM
trying to get educated about house wiring ChrisJJ Electrical 7 08-08-2010 03:23 PM
