Stove Hook Up - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2013, 10:17 PM   #1
Rewards Points: 664
Stove hook up
I have not yet bought my stove, but I assume a 30 amp breaker with 8-3 is good to install to be ready?
crescere is offline   Reply With Quote
Old 11-24-2013, 10:51 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Most electric ranges require a 40 or 50 amp circuit (8/3 or 6/3 cable).
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
jbfan (11-24-2013)
Old 11-25-2013, 07:13 AM   #3
Rewards Points: 1,216
Don't assume anything, wait until you buy the stove a follow the manufacturer's installation instructions and electrical requirements.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-25-2013, 10:05 AM   #4
yeah, pick your stove first. is it all electric? electric oven/gas cooktop? all this matters in sizing the circuit.
itsnotrequired is offline   Reply With Quote
Old 11-25-2013, 10:19 AM   #5
PoleCat's Avatar
Rewards Points: 1,646
You can look up the parameters for any of the models you are interested in on the web and save some shoe leather.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-25-2013, 10:27 AM   #6
Polecat you have a good point there but I would go with caution.
Suppose you look up the specs. for a certain model # and you prewire and the last minute you see one on sale a lot cheaper and go with the cheaper model.
The prewire does not meet the recommended requirements of the cheaper one. It probably will though when it comes to stoves. We're talking DIY here got to be careful.
Old 11-25-2013, 10:30 AM   #7
PoleCat's Avatar
I have shot myself in the foot more than once that way. But I despise shopping so much I have learned to take my buyer's remorse pill like a man.
Old 11-25-2013, 12:18 PM   #8
Licensed electrician
Rewards Points: 1,240
If the wire with #6 and run 4 conductors they should be covered. The only trick is getting the receptacle in the correct spot.
Electric stove hook up Mallard1123 Electrical 12 10-22-2012 11:26 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Small H2O line running up woodburing stove mibson HVAC 3 01-22-2011 10:14 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
