Stove Electrical And Odd Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2014, 10:17 PM   #1
Rewards Points: 131
Stove electrical and odd wire?
Hi. I am remodelling my kitchen. When I pulled the stove out, I discovered the box out of the wall and only a few inches above the floor. There is a white wire running through the same hole as the stove electrical. The electrical box is in a room in the basement somewhat close to where these wires penetrate the floor. The white wire goes into the cabinets and runs to a location I have not yet discovered.
I plan on replacing the drywall behind the stove and behind the cabinets where the white wire runs so accessing the studs is not an issue.
Suggestions?
Thanks,
Mark
wwkayaker is offline   Reply With Quote
Old 06-12-2014, 11:34 PM   #2
Rewards Points: 732
I cannot read the post very well, the kwikset ad covers a part of it, and the picture needs to be at a better angle.
That white wire looks to me to be a standard household extension cord, A no-no in any outlet wiring. If that is the case, it needs to go. When you tear out the old wall you will probably find a hidden junction box too, (another no-no.),
Suggest that you do more searching in the wall to find the source and either eliminate it or wire it correctly.
ED
de-nagorg is online now   Reply With Quote
Old 06-13-2014, 12:58 AM   #3
dmxtothemax's Avatar
Rewards Points: 5,096
Please supply a better picture ?
Closer view, so we can better see the cable.
Better lighting so we can see it clearly.
What size is the cable, I E what diameter ?
:whistling2
dmxtothemax is offline   Reply With Quote
Old 06-13-2014, 08:57 AM   #4
Rewards Points: 1,832
A surface mount box is right for this if you want it on the floor. The other option is putting it in the wall via nail one box or old work box if you don't want to remove sheetrock.
Pics of the cable and outlet just to see whats up with that.
Thanks!
Jump-start is offline   Reply With Quote
Old 06-13-2014, 09:53 AM   #5
joed's Avatar
Rewards Points: 11,552
Since the drywall will be removed simply feed the cable through the studs like would normally be done in new construction.
The stove box can be mounted in the wall right at the floor level.
Old 08-30-2014, 07:11 PM   #6
Rewards Points: 131
I just got back to doing this renovation. I am including what I hope is a better picture. There is not a hidden junction box in the wall. Both the white wire and stove wire go straight to the breaker from what I can tell. The white wire is a fix I understand and will take care of shortly.
With the new kitchen cabinet positions, the closest edge of the stove will be 20 inches from the outlet. I tried pulling (gently) more of the stove cable through the floor but it doesn't move so I assume there is no slack. The basement is finished with drywall so I can't see what I have there.
Old 08-30-2014, 07:12 PM   #7
Rewards Points: 131
A closer look at the wires and outlet.
Old 08-30-2014, 10:08 PM   #8
Rewards Points: 732
I would get new wire for the stove circuit, and just rewire it to code , that way it is safer for myself and family.
Disconnect the wire at the breaker box, hook the new wire to the old wire, making sure that the connection is solid, and not much larger than the old wire.
Then go up to the outlet, pull the old wire up and out GENTLY, pulling the new with it, And give yourself all the slack you need. take the old off the new, and install a new outlet wherever convenient. re attach the new wiring to the breaker box. And dispose of that small white one, it is a spark waiting to happen.
What does that lampcord (small white one) power anyway?
ED
Old 08-30-2014, 10:59 PM   #9
Rewards Points: 131
I was thinking of hooking the two wires together and pulling a new wire through but was concerned I might have them come apart but I think it is my best choice. The white wire powers the dishwasher.
Old 08-31-2014, 04:25 AM   #10
Rewards Points: 732
The dishwasher? That ain't safe at all. You need to get it on a circuit maybe shared with the microwave, or something else.
Lampcord is not rated for the draw that a dishwasher can pull.
So there is two that need repaired, maybe more.
ED
Old 08-31-2014, 07:09 AM   #11
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
I think it's NM and he earlier stated its getting replaced,
clw1963 is offline   Reply With Quote
Old 08-31-2014, 08:54 AM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I do t even see any issues here? Except for the floating box for the range, if anything, I would change it out to a surface mount range receptacle... As for the DW circuit, as long as it is out of harms way, I see no violations here, but I would relocate it to the sink cabinet and make it a receptacle and install a cord on the dishwasher.
Old 08-31-2014, 09:44 AM   #13
joed's Avatar
The problem is the box is NOT behind the stove. If the breaker panel is in the direction you need to move the box then you should be able to pull the cable down and feed it back up in the proper place. Drywall is easy to patch.
The Following User Says Thank You to joed For This Useful Post:
Stubbie (08-31-2014)
Old 08-31-2014, 11:54 AM   #14
E2 Electrician
How did we come to this conclusion, Im missing this part?
Never mind, found it in post #6....
Old 08-31-2014, 12:52 PM   #15
Rewards Points: 131
There is a junction box behind the stove. Could I run a wire to this to power the dishwasher?
