Stopping Cold Air Flow - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2008, 12:31 AM   #1
stopping cold air flow
Opened up the house panel today to add a circuit and found out why there was frost on it. The spider web in front of the pipe where the feed comes in was blowing back and forth.
Is it against code to use great stuff or insulation to plug the hole? If it is, anything else I can do?
thanks
--Mike
rsplash40 is offline   Reply With Quote
Old 12-21-2008, 08:13 AM   #2
Rewards Points: 862
Is the air coming in through the pipe, or around it?
If it's around the pipe, then you can probably use anything (non-flammable) that you want, but if it's through the pipe itself, there are limitations to what you can use.
Also, I would put the insulation outside, not inside, especially not inside the panel enclosure.
Ultrarunner2017 is offline   Reply With Quote
Old 12-21-2008, 12:03 PM   #3
yes, its through the pipe, putting it on the outside sounds like better idea, anything in particular I should/shouldn't use?
thanks
73
Old 12-21-2008, 12:09 PM   #4
Res Ipsa Loquitur
In my area either great stuff or pure silicone caulk is used outside around the SE cable.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 12-21-2008, 04:52 PM   #5
An old Tradesmen
Rewards Points: 6,568
Thumb dumb works fine also.
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Cold Flow geothermal unit napper HVAC 1 07-12-2008 05:20 PM
AC freezing up and stopping air flow bryanewade HVAC 10 06-11-2008 09:06 PM
