-   -   stopping cold air flow (http://www.diychatroom.com/f18/stopping-cold-air-flow-34145/)
rsplash40 12-21-2008 12:31 AM
Opened up the house panel today to add a circuit and found out why there was frost on it. The spider web in front of the pipe where the feed comes in was blowing back and forth.
Is it against code to use great stuff or insulation to plug the hole? If it is, anything else I can do?
thanks
--Mike
Ultrarunner2017 12-21-2008 08:13 AM
Is the air coming in through the pipe, or around it?
If it's around the pipe, then you can probably use anything (non-flammable) that you want, but if it's through the pipe itself, there are limitations to what you can use.
Also, I would put the insulation outside, not inside, especially not inside the panel enclosure.
rsplash40 12-21-2008 12:03 PM
yes, its through the pipe, putting it on the outside sounds like better idea, anything in particular I should/shouldn't use?
thanks
73
handyman78 12-21-2008 12:09 PM
In my area either great stuff or pure silicone caulk is used outside around the SE cable.
beenthere 12-21-2008 04:52 PM
Thumb dumb works fine also.
