Stobe Light Ground Wire Getting Hot! - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2008, 08:43 PM   #1
Stobe light ground wire getting hot!
i have installed a strobe wire system in my car. the directions say to take the red wire and connect it to a switch and then to my car battery and take the black wire, ground it to the car's chassis. i have done that and it didnt work so i ran a black wire from my battery's negative side and connected it to the other side of the switch. now when the switch is in the on position everything is working fine. but when i switch it to of and the lights go out, the ground or negative wire gets hot. i know there is a way to make this work where i can transfer the energy coming from the battery while the strobes arent on....need help with this desperately dont want my car to catch fire
kaliyg is offline   Reply With Quote
Old 08-21-2008, 09:05 PM   #2
Rewards Points: 6,652
Sounds like you have a short, along with wrong gauge of wire. You need a fuse on the Positive side, and if you did not do it during the install, you are looking at a Firestarter.
Old 08-21-2008, 09:11 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
So you are saying you have the negative AND the positive connected to the switch???
I would keep a fire extinguisher handy if I were you.
Old 08-21-2008, 09:27 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
I love your answer Pete. You beat me to it.
Re-read the instructions. How many terminals on the switch?? If there are 2, then the load (your lights) should be on one term, and the battery (running through a proper size fuse) on the other. Re-read the instructions. If there are 3 terms, re-read the instructions. Some 3 term switches require a ground hookup to illuminate the bulb inside the switch itself, to show you the switch is on. Re-read the instructions.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
