Still Need Help With Dayton Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 09:27 PM   #1
still need help with dayton heater
so the dayton heater #2yu68 can be wired at 240v with a 60 amp breaker?also there is a terminal in the heater that says attach thremostat wires here so do i need a transformer or anything or do i just attach the wires to the terminals and thats it?what size wire should i use for the power?
phil dufour is offline   Reply With Quote
Old 04-19-2009, 09:38 PM   #2
Electrical Contractor
kbsparky's Avatar
Nope. That heater can NOT be wired for 240 Volt operation. It is rated for 208 Volts only. Dayton makes other units rated for dual voltage operation, such as their model 2yu69
Installing it with a 240 volt supply will probably result in the elements burning out due to excessive voltage.
See chart of the different models here.
Old 04-19-2009, 09:40 PM   #3
Electrician
Rewards Points: 802
The heaters I have seen that have a terminal connection for the stat will use a low voltage stat(usually 12 or 24V). Is there a website so we can get more information on your heater
darren is offline   Reply With Quote
Old 04-19-2009, 09:51 PM   #4
kbsparky's Avatar
Click the link in the earlier post.
You are correct, in that there is a 24Volt transformer internal with the unit.
Dayton 3E837 unit heater manual spolit HVAC 42 03-14-2017 08:18 AM
Dayton gas heater ventureman HVAC 7 11-11-2013 09:11 PM
Problems with Dayton 5UT20 hot water garage heater tcellis HVAC 3 03-17-2009 03:28 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
