Old 01-30-2008, 08:09 AM   #61
waiting for spring
arichard21's Avatar
Sticky Situation
Originally Posted by Joe F View Post
Although I've only been a member of this site for a few days, I'm afraid this is all my fault.
1. I work for the government
2. My cordless extension cord appears to have some flaws.
Touche!
arichard21 is offline   Reply With Quote
Old 01-30-2008, 09:05 AM   #62
Once fried, twice shy.
elkangorito's Avatar
Sticky Situation
Originally Posted by elias144 View Post
they actually dont have to be that sneaky because im gone for 9 hours a day. 440volt dc? very interesting. what type of material would i use to encase this? lead foil? i used regular aluminum foil and its made a little difference. i have been shutting off certain breakers and that works but what else could i do?
Where do you go for 9 hours each day?
It appears that some people have some strange ideas about "shielding". Firstly, aluminium foil will not shield against magnetic flux. It will, however, provide some shielding against EMR, depending upon the frequency.
Zero EMR is produced from a pure DC source but if DC current is flowing through conductors, a magnetic flux will be created. Also, an effective Faraday Shield cannot be created by alone using something like lead foil. This type of shield requires 2 things; a dense material with high reluctance to magnetic fields (brass is very good & easily obtainable) & another dense material that has high permeability to magnetic flux (soft iron). The former (brass) is placed inside of the latter (iron).
Elias, it appears to me as though you do not know what you need to shield yourself against. If you think that you are getting some relief from wrapping your head in aluminium foil, then EMR could be your problem. The level of radiation (EMR) is proportional to the level of voltage & frequency. The strange thing is that for EMR shields to be effective, they need to be earthed & totally surround the thing that needs to be shielded. Is your face exposed? If so, the shield is not effective at all. Since you claim hypersensitivity to "something", it makes no sense at all that foil can provide any relief since;
1] the foil is not earthed &
2] your face is probably exposed.
My conclusion is that you are imagining all of this.
Exactly when did you develop this hypersensitivity to "something" electrical?
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
Old 01-30-2008, 09:18 AM   #63
Electrical Contractor
Sticky Situation
At least we have someone from the goverment that admits to something!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-30-2008, 12:52 PM   #64
Licensed Electrical Cont.
Speedy Petey's Avatar
Sticky Situation
Now go sit in the corner and think about what you've done.
Old 02-03-2008, 01:25 PM   #65
Sparrky
Sticky Situation
well since you had the courage to ether entertain us or state a truthful situation as . . .YOU . .believe it
I'll take a stab at an honest answer
A. I am in the military . . .and in the 5 years plus I have been in . .I am afraid I must report that . . .uhm . .well . . .I have yet to be briefed on when our "mid control' courses will begin
B. accept that there are numerous and varied types of waves going through your home .and thus your brain every second of everyday . .IE radio waves ..microwaves...TV signals . .your4 cell phones . .TV at thrr feet distance lays out a great EMF . . .etc etc and in al truthfullness we may nit know at this time what the unintended consequences of our industry may hold after longer term studies
C. as an observer I would =like to try a few tests . .and to be accurate that must be blind tests
have a friend that you trust to be cnmpletly honest . .help you
Test 1 . . . . .have friend blind fold you . . .turn you this way and that
in an location OTHER than your home . . .and have them walk you past
a larger TV ...on but volumne off . . . .an MAIN panel box . . .with both inserted ear plugs and OVER ear hearing protectors . .have them walk you past an RUNNING microwave oven
this is important . . . .you are to state when and what kind of reactions you have and where IE stop when you get an reaction . .friend will note in notepad where...proximity to which devices etc etc
then a second test is to be run . .having them walk you past the same devices . .which will now be turned off . .again you will stop when you have any reaction . .friend will note results of where...proximty distance to whcih device . . .and since you are obviously intelligent . . . .during both tests some of the appliances will be on and some wont so y=that you cannot
remember which is which
this will eliminate or confirm your symptoms as real or pychosematic
now..this part of the test wil be most fascinating . . .IF . . .and please be honest with obtaining results here if you want to diagnos your symptoms
. .IF you "reacted " to any of the devices . . .in qan blind and varied sets of tests . .I want you to try the following . . . .OKAY OKAY after you've stopped belly laughing
its about dssheliding and ground away interference . . .I do want you to find an metal pot . .NOT aluminum . .be clear about this . . .and then run the tests as stated above with a meatl ( but not aluminum ) pot over your head . .pot should be large enough to cover below your ears
Again have your freind . . .a different friend this time . . .log the results
vary what is turned on and what is not
Last test . . .get a long extention cord..or long piece of copper wire . .and using alligator clips . .crew type clamps would be better . . .clamp one end to the pot you are using as an shield . . .and the other end to a water pipe
run the tests a final time
there is no point in doing this if you cannot do them honestly
but if you can objectivly perform them . . .you sure as hell are going to be stunned by the results . . . .email me the results please
won4thewoad@yahoo.com
Kingsmurf is offline   Reply With Quote
Old 02-03-2008, 07:54 PM   #66
Electrician's Helper
Pudge565's Avatar
Send a message via AIM to Pudge565
Sticky Situation
Originally Posted by Bondo View Post
Ayuh,....... I think my fellow Maineiac head the nail on the head,......
The Faraday Cage Effect is probably your Only Defense.........
Unfortunately,.... Lead Foil is no longer available,.....
I don't know if a single or double layer of Aluminum Foil would be enough,.......
Maybe encasing a layer of Aluminum Screen into the layers of Foil will Help,......
If the Foil,+ Screen Hat doesn't work,.....
You might try a jacket/ hood arrangement of the Foil,+ Screen.................
Btw,........ Tell the rest of the Sir Charles Barkley's Five group that I said, Hi..............
lead foil is still available mythbusters used it to make a lead baloon. i think they got it from some place in germany. and just so you know it was filmed in 2007
Pudge565 is offline   Reply With Quote
Old 02-03-2008, 08:18 PM   #67
nap
You talking to me?
nap's Avatar
Sticky Situation
Is anybody here a pole jock? If so, maybe elias could use one of your faraday suits but he would need to ground it and figure out something for his face.
the suit he has on has stainless steel throughout.
Old 02-04-2008, 11:08 PM   #68
Electrician philosopher
Sticky Situation
I've been off for a while... this might be the very best thread ever. You are helping Stub.
talking to Bonk... Hold on...
Andy in ATL is offline   Reply With Quote
Old 02-05-2008, 12:22 AM   #69
Sticky Situation
I've also talked to Buds who say you don't have to pay taxs and GB killed all those people in NY.
I've also talked to people who said O.J. was not guilty.
Old 02-05-2008, 12:29 AM   #70
Sticky Situation
Originally Posted by 220/221 View Post
Do you have ANY idea how much EMF/ microwaves and sh!t pass thru your brain ?
Waves are a B#$%t
Old 02-05-2008, 07:00 AM   #71
waiting for spring
arichard21's Avatar
Sticky Situation
Hey. he IS innocent...
*fires up flamethrower*
Waste Stack backing up.... J187 Plumbing 20 11-06-2007 07:06 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
