Sticky Cuttler Hammer CH - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 11:46 AM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Last night when I was working on the panel I was putting in a few more breakers, and noticed a problem that I had before. Some of the breakers are really really hard to get in. So hard that I could not get a couple in, I stopped as I was afraid of damaging the bus.
I had this happen before and I returned the breakers in question.
Does this happen normally when out of a full panel you find a couple that just don't want to go in?
Should I try to open up the contacts on the breaker somehow and try again or should I treat these as manufacture defects?
All breakers & the panel were purchased via authorized retail outlets, Menards, Home Depot, or Lowes.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-07-2009, 12:31 PM   #2
DIYer
Whatever you do, don't do this. I would keep the breakers and write to CH, they would probably be interested in them for QA purposes, and would likely send you free replacements in exchange for you mailing them the bad ones.
Gigs is offline   Reply With Quote
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
please help select a rotary hammer amakarevic Building & Construction 9 07-04-2008 12:58 AM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 10:19 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
Water Hammer ffgus Plumbing 3 12-31-2006 10:19 AM
